I've a new custom board with IMX6UL configured to boot on USDHC1 controller with an eMMC connected.
I can't find a document describing what's the IOMUX configuration used by the ROM Bootloader when it starts, in order for me to be sure that the way I connected some signals is correct.
My specific problem is related to the nRST signal of the eMMC which is connected to NAND_WP_B (which has the USDHC1_RESET_B function available). What I/O is used by the ROM Bootloader for this function?
Do you have a document describing the complete I/O mapping used by the ROM Bootloader?
解決済! 解決策の投稿を見る。
Hi Christophe
I/O mapping can be found in Table 8-18. SD/MMC IOMUX Pin Configuration
i.MX6UL Reference Manual
http://www.nxp.com/docs/en/reference-manual/IMX6ULRM.pdf
Hi Christophe
Thank you! I missed this table in the Reference Manual!
