let me remind, for 32-bit addresses 4GB is maximum address area.
But some address range should be left for peripherals.
Yuri.
blockquote, div.yahoo_quoted { margin-left: 0 !important; border-left:1px #715FFA solid !important; padding-left:1ex !important; background-color:white !important; } Hi Yuri,Thank you If we would need to have 8gb, is it possible?
Does ARM V7-A CPU architecture provides a way ThanksKishor
Sent from Yahoo Mail for iPhone
If 8gb means 8GBytes - I am afarid - we cannot support it under i.MX6.
Yuri.
Hi Kishor
this is defined by max. supported row/col parameters described
in sect.44.12.1 MMDC Core Control Register (MMDCx_MDCTL) i.MX6DQ Reference
Manual (rev.3 7/2015)
http://cache.freescale.com/files/32bit/doc/ref_manual/IMX6DQRM.pdf
