IMX6Q mipi-csi2 connect four cameras
已解决
跳至解决方案
1,367 次查看
meifangchang
"Hello, I'm currently using IMX6Q and I want to use MIPI-CSI2 to connect four cameras simultaneously. How should I configure the device tree?"
1 解答
1,341 次查看
joanxie
3 回复数
1,342 次查看
joanxie
1,318 次查看
meifangchang
Hello, I used this document. The issue now is that video1, video2, and video3 are working fine, but video4 is not working.
The printed content is as follows:
ERROR: v4l2 capture: mxc_v4l_dqueue timeout enc_counter 0
The 19th and 20th bits of IMUXC_GPR1 have been configured as 0.
1,302 次查看
joanxie
it's hard to find the root cause according to your one error message, maybe you can refer to the link as below to get some hints
"https://community.nxp.com/t5/i-MX-Processors/i-MX6-OV5647-Bayer-sensor-driver-ERROR-v4l2-capture-mxc..."
