IMX6Q-SDB,help, update emmc from sdcard
1,036 次查看
tab_song
i wanna update emmc on imx6q-sdb broad from sd card
What should i do ?
标签 (2)
标记 (3)
4 回复数
902 次查看
Rita_Wang
If you want to boot up the board from emmc. Here you can use the mfgtool to download the images to emmc first and then boot up from emmc. In our website there are different version BSP and same version mfgtool, you can choose which you need.i.MX 6 / i.MX 7 Series Software and Development Tool|NXP
Hope this can help you.
Rita
902 次查看
tab_song
i kown use mfgtool.
i wanna do this work
1. a sdcard insert SD solt
2. power on
3. according to cfg in sdcard, doing EMMC partition, write uboot kernel rootfs on EMMC
i find uboot haven`t fdisk command
902 次查看
Rita_Wang
Which version of BSP are you using?
Best Regards
Rita
902 次查看
tab_song
