IMX6Q MfgTool burn program failed
Search instead for
tommyduan
We use Mfgtool burn program ,it stop"jumping to os image",can't going on!How can we find the reason?before it's ok,Where should I look for the reason?How does the burning process run?How does the system process work after startup?
Hi tommy
stop"jumping to os image" may mean that board can not run mfg tool
since ddr settings are wrong for that board. It s necessary to run ddr test
i.MX6/7 DDR Stress Test Tool V2.92
https://community.nxp.com/docs/DOC-328258
and rebuild mfg tool with new ddr settings found from ddr test.
For example one can look on
How to build MFG Firmware for i.MX6Q
