IMX6DQ : Recording only recorded 5s, then an error occurs
michelcui
  cpu : imx6DQ ( 4 cpus )
  software : android-R13.4-ga
  kernel : linux-3.0.35
  Audio codec : ES8388
  When I was recording 5s or so, there will be errors.And then you can never recording until restart.
     LOGCAT :
W/AudioRecord( 2131): obtainBuffer timed out (is the CPU pegged?) user=00009c60, server=00009c60
V/MediaRecorder( 2895): getMaxAmplitude
V/MediaRecorder( 2869): getMaxAmplitude
E/audio_hw_primary( 2131): get_next_buffer() pcm_read error -1
W/audio_hw_primary( 2131): ret -1, pcm read error cannot read stream data: I/O error.
W/audio_hw_primary( 2131): ret -1, pcm read error cannot prepare channel: Device or resource busy.
Labels (2)
jasonoh
Good Day!
My name is Jason Oh from South Korea.
Did somebody solve this problem ?
I have ported android 7.1.2 to IMX6DQ with WM8960 codec.
I have facing same issue.
Can somebody help me?
Best Regards.
Jason Oh
daiane_angolini
Is there any message from kernel? Can you share your dmesg?
Have you double checked if you have free space on your SDCard?
manishbadarkhe
We are also facing almost same issue. Is there any resolution for this issue?
Manish Badarkhe
