hello,
I'm designing a PCB with IMX6Q connect to 512MByte DDR3 (2 chips) with a 32 bit data bus. how i should connect the unused pins (DRAM_D32:63, DRAM_SDQS4:7,DRAM_SDQS_B4:7 and DRAM_DQM4:7)? leave floated , ground... ?
thanks,
omri
If you try searching the community for 32 bit ddr3 you would find numerous hits that would help you here -
Appropriate termination for unused DDR3 pins on a i.MX6 dual/quad design with 32-bit bus
https://community.nxp.com/message/589115
There are other threads also that may be of use/interest.
Ross
