Dear Community,
SOC: IMX6
OS : WinCE 2013
We are facing strange issue in some of our systems.
System time in winCE machines is running faster . here we are observing 1 minutes gets complete 20 to 30 seconds (this is varying in different machines).
We are testing time using GetLocalTime(); GetSystemTime(); windows API. And its output time is running faster.
Although RTC time is running ok and also we are not syncing time from SNTP in our testing.
please suggest what could be the issue.
One work around : when we disconnect IMX6 board from our system and reconnect it then this issue gets solve.
Have you solved this problem yet? I might be give it a try
please email to me: kaka@baittek.com
One can check if correct image was used as "sabre sdb" is generic name for several boards with different processors: i.MX6Q, DL, SX. For procedure issues may be sense to contact witekio directly as nxp does not support wince on i.MX6 platform.
