Thank you very much for your prompt reply Yuri.
You said "Basically external tampering should work".
The words "Basically" and "should", kind of implies that there are some cases that it does not work ???
Because you did not reply like "tampering always works and all secure memory content is always deleted"
So i am a little bit confused again.
Can you please help me to understand, Is it always possible to delete "Secure Memory" contents at every possible scenario ?
Or is there some open points ?
This is a very important issue for us because we are planning to store private keys and/or digital certificates in the non volatile region of "Secure Memory" of IMX6.
If IMX6 has some open points on this regard we have to find another solution.
