Hello, I hope you are doing well.
ROM code will always try to find a valid image for booting in the selected boot device, unless serial download is selected.
There is only 2 ways to inputs that control the behavior of the Boot ROM code, Fuses or GPIO.
If everything is correct ROM code will execute the code and continue the boot sequence.
Is it possible to check if there is some issue that is causing switch to serial download mode? (such as boot mode pins voltage levels).
Does the issue occur only by using the reboot command?
Best regards.
