IMX6 Quad and Quad Plus 2 channel H/W encoding performance
ソリューションへジャンプ
2,703件の閲覧回数
ivyliu
We want to try 2 channel H/W encoding simulaneously with IMX6 Quad or Quad Plus with 1080P or 720P.
We will use H.264.
Could someone tell me what is the highest 2 channel H/W encoding simulaneously performance for both Quad and Quad Plus with 1080P and 720P?
Can they both be 1080P@30fps?
Thanks and Best Regards,
Ivy
ラベル(2)
2,444件の閲覧回数
Hi Ivy
please check p.6 presentation for simultaneous encode performance
Q&A: MX6 VPU H.264 Dual Stream Encode Limits | NXP Community
i.MX6Q and QP have the same vpu module.
5 返答(返信)
2,445件の閲覧回数
Hi Ivy
2,444件の閲覧回数
ivyliu
Hi Igor,
Thanks for your prompt reply.
Do you know what would be the maximum throughput when VPU is operating at 352 MHz?
Ivy
2,444件の閲覧回数
Hi Ivy
below link may be useful
Memory Reserved on i.MX6 for VPU
2,444件の閲覧回数
ivyliu
Hi Igor,
Thank you for your reply.
I will try to decrease the size.
Ivy
2,444件の閲覧回数
Hi Ivy
please check suggested presentation, it shows in brackets (vpu>300MHz)
