I am wondering if anybody else is having issues with the gstreamer (gst-fsl-plugin) mfw_v4lsrc.
I am using LTIB 12-09 version (downloaded from Extranet) - as follows:
root@Tom ~$ gst-inspect mfw_v4lsrc
MFW_GST_V4LSRC_PLUGIN 3.0.1 build on Nov 1 2012 14:31:47.
Factory Details:
Long name: v4l2 based camera src
Class: Src/Video
Description: Capture videos by using csi camera
Author(s): Multimedia Team <shmmmw@freescale.com>
Rank: primary (256)
Plugin Details:
Description: v4l2-based csi camera video src
Filename: /usr/lib/gstreamer-0.10/libmfw_gst_v4lsrc.so
Version: 3.0.1
License: LGPL
Source module: gst-fsl-plugins
Binary package: Freescle Gstreamer Multimedia Plugins
Origin URL: http://www.freescale.com
GObject
+----GstObject
+----GstElement
+----GstBaseSrc
+----GstPushSrc
+----MFWGstV4LSrc
Pad Templates:
SRC template: 'src'
Availability: Always
Capabilities:
ANY
Element Flags:
no flags set
Element Implementation:
Has change_state() function: gst_base_src_change_state
Has custom save_thyself() function: gst_element_save_thyself
Has custom restore_thyself() function: gst_element_restore_thyself
Element has no clocking capabilities.
Element has no indexing capabilities.
Element has no URI handling capabilities.
Pads:
SRC: 'src'
Implementation:
Has getrangefunc(): gst_base_src_pad_get_range
Has custom eventfunc(): gst_base_src_event_handler
Has custom queryfunc(): gst_base_src_query
Has custom iterintlinkfunc(): gst_pad_iterate_internal_links_default
Has getcapsfunc(): gst_base_src_getcaps
Has setcapsfunc(): gst_base_src_setcaps
Has acceptcapsfunc(): gst_pad_acceptcaps_default
Aborted
If I use Timesys version (using web based linuxlink) this works just fine!
I am not sure what is going on here?
Tom
TOm
This discussion is closed since no activity. If you still need help, please feel free to reply with an update to this discussion, or create another discussion.
Yixing
TOm
We have not got your response yet and will close the diacussion in 3 days. If you still need help, please feel free to
reply with an update to this discussion.
Yixing
Tom
We are sorry for getting back to you so late. Are you still stuck with the issue? If you have somehow to resolved the issue, can we close the discussion? If you still need Freescale help, please feel free to contact us.
Yixing
this is the only problem you faced?
I've never payed attention if this happened to my anytime.
