IMX6 CSI BT656 640x480 interlaced support
已解决
跳至解决方案
2,552 次查看
abeeshmp_dct
Hi Team,
Does imx6 CSI support 640x480 interlaced video in BT656 embedded SYNC protocol ?
标签 (1)
1 解答
2,137 次查看
yes supported.
在原帖中查看解决方案
4 回复数
2,137 次查看
Hi ABEESH
unfortunately i.MX6SL does not support it, support was added in later
i.MX6 products with CSI module, please check for example DEINTERLACE_
STRIDE description in sect.19.7.12 CSI Frame Buffer Parameter Register
(CSI_CSIFBUF_PARA) i.MX6UL Reference Manual
http://www.nxp.com/docs/en/reference-manual/IMX6ULRM.pdf
2,137 次查看
abeeshmp_dct
Hi igorpadykov,
Thank you very much for immediate reply.
In imx6, is that the limitation of CSI module or De-interlacing(VDIC) module.
BT656 640x480 Progressive mode is supported?
2,138 次查看
yes supported.
2,137 次查看
abeeshmp_dct
Thanks Igor.
