IMX6 CSI BT656 640x480 interlaced support
Search instead for
Hi Team,
Does imx6 CSI support 640x480 interlaced video in BT656 embedded SYNC protocol ?
yes supported.
Hi ABEESH
unfortunately i.MX6SL does not support it, support was added in later
i.MX6 products with CSI module, please check for example DEINTERLACE_
STRIDE description in sect.19.7.12 CSI Frame Buffer Parameter Register
(CSI_CSIFBUF_PARA) i.MX6UL Reference Manual
http://www.nxp.com/docs/en/reference-manual/IMX6ULRM.pdf
Hi igorpadykov,
Thank you very much for immediate reply.
In imx6, is that the limitation of CSI module or De-interlacing(VDIC) module.
BT656 640x480 Progressive mode is supported?
yes supported.
Thanks Igor.
