IMX287 nandflash driver port
Zhang_123
The IMX287 requires a port of nand-flash material, model GD9FU1G8F2AMGI.
Is there a corresponding driver? Thank you so much
Zhang_123
Hi, thanks for the information. http://wiki.freescale.net/display/PSGSW/Hynix+NAND+Flash+Documents is not work,Could you provide a new link to the analysis spreadsheet please? Thanks!
joanxie
you also can refer to the link as below:
"https://community.nxp.com/t5/i-MX-Processors/To-port-new-driver-for-nand-on-i-mx28/m-p/293712"
for Hynix NAND Flash Documents, I post one example for you, about H27UBG8T2M, I attached the data sheet and analysis xls file, pls find them
joanxie
