IMX287: example output on LCD
1,143件の閲覧回数
BrilliantovKiri
Senior Contributor I
Hello!
I have to output image and video on LCD display (480x272).
I try use gstreamer: gst-launch videotestsrc ! fbdevsink, unfortunately I not see any.
Where can I found example output image and video on LCD display for iMX287?
Thank you and excuse my bad english.
Upd: After correct clock-frequency all work fine.
ラベル(2)
タグ(1)
996件の閲覧回数
Hi Kirill
if one uses official FSL BSP (from freescale product page i.MX28 Evaluation Kit|Freescale)
for video one should install codec package L2.6.35_1.1.0_LINUX_MMCODECS :
i.MX28 Linux Multimedia Codecs Documentation and Sources.
Linux_Multimedia_Framework_User_Guide.pdf in that package shows some examples,
FeatureMatrix_MX28.html - supported codecs and resolutions.
I am not aware about i.MX28 codecs for other distros, in general one
can also post that on meta-fsl-arm mailing list
https://lists.yoctoproject.org/listinfo/meta-freescale
