IM8QXP
IM8QXP
shalanyang
hello ,
1.I want to use call watchdog function in imx8qxp kernel, where function should I use ?could you tell me?
 2. I want to know some more detail information power and PMIC ,could you send me some doc ?
 tks!
shalanyang
I just know that when use echo c > /proc/sysrq-trigger, it will cause kernel panic in IMX8QXP target board. I want to use the watchdog to restart system. How can I enable it and use it? tks!
joanxie
1)for watchdog, pls refe to the chapter 2.11 Watchdog (WDOG) of enclosed file
2) for power consumption, pls refer to the application note as below:
https://www.nxp.com/docs/en/application-note/AN12338.pdf
shalanyang
thanks,I try it@
