IM6ULL failed to startup from SD card
jackjiang
Can anybody explain what is wrong with linux kernel?
Hardware is IM6ULL EVK and I built the image myself with Buildroot, u-boot works fine, but the kernel doesn't startup.
PS: Please take a look full log in attachments.
joanxie
how did you build your own image? did you change any source code?
