ICS android on 10" faytech HDMI [eGalax Inc. USB TouchController] Touchscreen issue
Search instead for
ShrikantBobade
I am trying to port ICS android on 10" faytech HDMI display, using imx6q target.
[Android base code @ git://github.com/boundarydevices/imx-android-r13.4-ga.git ]
Currently my ICS android set-up rendering well on the faytech HDMI display,
even with mouse registered events, I am able to use android well.
Now to add Faytech Touchscreen I have tried including these patches to include it well.
patches from android-x86 forum.
http://code.google.com/p/android-x86/issues/list?can=1&q=Faytech&colspec=ID+Type+Status+Priority+Mil...
Observed, the faytech touch-screen seems responding/partially working.
Mainly I am stuck at touch-screen  calibration to make android working well functional.
These are my setup few params..
root@android:/ # cat /proc/bus/input/devices
I: Bus=0003 Vendor=0eef Product=0001 Version=0100
N: Name="eGalax Inc. USB TouchController"
P: Phys=usb-fsl-ehci.1-1.1.2/input0
S: Sysfs=/devices/platform/fsl-ehci.1/usb2/2-1/2-1.1/2-1.1.2/2-1.1.2:1.0/input/input1
U: Uniq=
H: Handlers=mouse0 event1
B: PROP=0
B: EV=b
B: KEY=400 0 0 0 0 0 0 0 0 0 0
B: ABS=3
resoultion set..
root@android:/ # cat /sys/class/graphics/fb0/mode
S:1280x1024p-60
display registered well.
root@android:/ # cat  /sys/class/graphics/fb0/fsl_disp_dev_property
hdmi
Android gets the touch events well..
130|root@android:/ # getevent  /dev/input/event1
0003 0000 00000409
0003 0001 00000208
0000 0000 00000000
Looking out to use tslib/tools to fetch and use proper calibration.
Suggestions/pointers for preparing the faytech touch screen will be a great help.
Thanks in Advance..
Best Regards
Shrikant
Labels (4)
daiane_angolini
Do you have it working when you test with getenv?
You should create an idc file Input Device Configuration Files | Android Open Source
Take your logcat in order to find your touchscreen driver being loadded. You can find the idc content in logcat.
Please, let me know the results :smileywink:
daiane_angolini
ShrikantBobade
Thanks for responding,,
With adding proper supporting idc file, display detected well by android system verified @ logcat.
w.r.to  http://www.mail-archive.com/android-porting@googlegroups.com/msg18201.html
It helped in making android home screen responsive.
- Thanks
Shrikant
