I am trying to port ICS android on 10" faytech HDMI display, using imx6q target.
[Android base code @ git://github.com/boundarydevices/imx-android-r13.4-ga.git ]
Currently my ICS android set-up rendering well on the faytech HDMI display,
even with mouse registered events, I am able to use android well.
Now to add Faytech Touchscreen I have tried including these patches to include it well.
patches from android-x86 forum.
Observed, the faytech touch-screen seems responding/partially working.
Mainly I am stuck at touch-screen calibration to make android working well functional.
These are my setup few params..
root@android:/ # cat /proc/bus/input/devices
I: Bus=0003 Vendor=0eef Product=0001 Version=0100
N: Name="eGalax Inc. USB TouchController"
P: Phys=usb-fsl-ehci.1-1.1.2/input0
S: Sysfs=/devices/platform/fsl-ehci.1/usb2/2-1/2-1.1/2-1.1.2/2-1.1.2:1.0/input/input1
U: Uniq=
H: Handlers=mouse0 event1
B: PROP=0
B: EV=b
B: KEY=400 0 0 0 0 0 0 0 0 0 0
B: ABS=3
resoultion set..
root@android:/ # cat /sys/class/graphics/fb0/mode
S:1280x1024p-60
display registered well.
root@android:/ # cat /sys/class/graphics/fb0/fsl_disp_dev_property
hdmi
Android gets the touch events well..
130|root@android:/ # getevent /dev/input/event1
0003 0000 00000409
0003 0001 00000208
0000 0000 00000000
Looking out to use tslib/tools to fetch and use proper calibration.
Suggestions/pointers for preparing the faytech touch screen will be a great help.
Thanks in Advance..
Best Regards
Shrikant
Solved! Go to Solution.
Do you have it working when you test with getenv?
You should create an idc file Input Device Configuration Files | Android Open Source
Take your logcat in order to find your touchscreen driver being loadded. You can find the idc content in logcat.
Please, let me know the results :smileywink:
Thanks for responding,,
With adding proper supporting idc file, display detected well by android system verified @ logcat.
w.r.to http://www.mail-archive.com/android-porting@googlegroups.com/msg18201.html
It helped in making android home screen responsive.
- Thanks
Shrikant
