I2C to SPI sc18is602 not generating clock
1,550 次查看
andrewbarnett
I have no clock or data generated by SC18IS602 chip.  I can addres the chip and alter the state of the gpio lines but sending a function id of 01 - 0f does not do anything.  Anyone have ideas or woring arduino code they can share
1 回复
1,305 次查看
Hi Andrew
ona can check timings as described on
I2C to SPI using SC18IS602B
and look at linux driver :
linux/spi-sc18is602.c at master · torvalds/linux · GitHub
