I would like to use uart4 in imx8mm
932 次查看
takeshi100
According to the following web site, I fixed device treee and imx8mm_bl31_setup.c.
But, Kernel panic still was happened.
Is there anything else I should do?
■ web site
https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/How-to-use-UART4-on-iMX8M-from-Linux-Use...
■ log
[2025-01-07 19:50:13.705] [ 0.126548] Bus freq driver module loaded
[2025-01-07 19:50:13.705] [ 0.137182] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[2025-01-07 19:50:13.705] [ 0.139992] 30860000.serial: ttymxc0 at MMIO 0x30860000 (irq = 15, base_baud = 5000000) is a IMX
[2025-01-07 19:50:13.705] [ 0.140121] serial serial0: tty port ttymxc0 registered
[2025-01-07 19:50:13.706] [ 0.140547] 30890000.serial: ttymxc1 at MMIO 0x30890000 (irq = 16, base_baud = 1500000) is a IMX
[2025-01-07 19:50:13.722] [ 0.140585] printk: console [ttymxc1] enabled
[2025-01-07 19:50:13.960] [ 1.308725] SError Interrupt on CPU3, code 0x00000000bf000002 -- SError
[2025-01-07 19:50:13.960] [ 1.308737] CPU: 3 PID: 1 Comm: swapper/0 Not tainted 6.6.23-lts-next-gd490f49646f0-dirty #1
[2025-01-07 19:50:13.960] [ 1.308744] Hardware name: FSL i.MX8MM EVK board (DT)
[2025-01-07 19:50:13.960] [ 1.308747] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
[2025-01-07 19:50:13.960] [ 1.308754] pc : imx_uart_probe+0x3e4/0x980
[2025-01-07 19:50:13.960] [ 1.308771] lr : imx_uart_probe+0x380/0x980
[2025-01-07 19:50:13.960] [ 1.308783] sp : ffff80008003bb30
[2025-01-07 19:50:13.960] [ 1.308785] x29: ffff80008003bb50 x28: 0000000000000000 x27: ffffb2254bc76068
[2025-01-07 19:50:13.960] [ 1.308799] x26: ffff2141444fd0c0 x25: 0000000000000011 x24: 00000000fffffffa
[2025-01-07 19:50:13.960] [ 1.308809] x23: ffff21414410bc10 x22: 00000000fffffffa x21: ffff21414410bc00
[2025-01-07 19:50:13.960] [ 1.308821] x20: 0000000000000000 x19: ffff2141448e8080 x18: ffffffffffffffff
[2025-01-07 19:50:13.973] [ 1.308832] x17: 1fffe428288813e1 x16: 0000000000000000 x15: ffff80008003b4d0
[2025-01-07 19:50:13.973] [ 1.308844] x14: ffffffffffffffff x13: 0000000000000018 x12: 0101010101010101
[2025-01-07 19:50:13.973] [ 1.308854] x11: 7f7f7f7f7f7f7f7f x10: ffffb6254db29d2f x9 : 0000000000000028
[2025-01-07 19:50:13.973] [ 1.308865] x8 : ffff2141444fd180 x7 : 0000000000000000 x6 : 000000000080e3ec
[2025-01-07 19:50:13.973] [ 1.308875] x5 : 0000000000000000 x4 : 0000000000000000 x3 : 0000000000000000
[2025-01-07 19:50:13.973] [ 1.308886] x2 : 00000000ffff4ddf x1 : ffff800080570080 x0 : 0000000000000001
[2025-01-07 19:50:13.973] [ 1.308901] Kernel panic - not syncing: Asynchronous SError Interrupt
[2025-01-07 19:50:13.973] [ 1.308904] CPU: 3 PID: 1 Comm: swapper/0 Not tainted 6.6.23-lts-next-gd490f49646f0-dirty #1
[2025-01-07 19:50:13.973] [ 1.308909] Hardware name: FSL i.MX8MM EVK board (DT)
[2025-01-07 19:50:13.990] [ 1.308913] Call trace:
[2025-01-07 19:50:13.990] [ 1.308915] dump_backtrace+0x94/0x114
[2025-01-07 19:50:13.990] [ 1.308929] show_stack+0x18/0x24
[2025-01-07 19:50:13.990] [ 1.308940] dump_stack_lvl+0x48/0x60
[2025-01-07 19:50:13.990] [ 1.308955] dump_stack+0x18/0x24
[2025-01-07 19:50:13.990] [ 1.308966] panic+0x31c/0x378
[2025-01-07 19:50:13.990] [ 1.308975] nmi_panic+0x8c/0x90
[2025-01-07 19:50:13.990] [ 1.308984] arm64_serror_panic+0x6c/0x78
[2025-01-07 19:50:13.990] [ 1.308993] do_serror+0x3c/0x70
[2025-01-07 19:50:13.990] [ 1.308998] el1h_64_error_handler+0x30/0x48
[2025-01-07 19:50:13.990] [ 1.309007] el1h_64_error+0x64/0x68
[2025-01-07 19:50:13.990] [ 1.309012] imx_uart_probe+0x3e4/0x980
[2025-01-07 19:50:13.990] [ 1.309021] platform_probe+0x68/0xc4
[2025-01-07 19:50:13.990] [ 1.309035] really_probe+0x188/0x3c4
[2025-01-07 19:50:14.005] [ 1.309044] __driver_probe_device+0x7c/0x16c
[2025-01-07 19:50:14.005] [ 1.309054] driver_probe_device+0x3c/0x110
[2025-01-07 19:50:14.005] [ 1.309066] __driver_attach+0xf0/0x1f8
[2025-01-07 19:50:14.005] [ 1.309077] bus_for_each_dev+0x7c/0xdc
[2025-01-07 19:50:14.005] [ 1.309086] driver_attach+0x24/0x30
[2025-01-07 19:50:14.005] [ 1.309095] bus_add_driver+0x114/0x224
[2025-01-07 19:50:14.005] [ 1.309104] driver_register+0x5c/0x124
[2025-01-07 19:50:14.005] [ 1.309117] __platform_driver_register+0x28/0x34
[2025-01-07 19:50:14.005] [ 1.309130] imx_uart_init+0x54/0x7c
[2025-01-07 19:50:14.005] [ 1.309140] do_one_initcall+0x80/0x1c8
[2025-01-07 19:50:14.010] [ 1.309147] kernel_init_freeable+0x1bc/0x284
[2025-01-07 19:50:14.010] [ 1.309157] kernel_init+0x24/0x1dc
[2025-01-07 19:50:14.010] [ 1.309163] ret_from_fork+0x10/0x20
[2025-01-07 19:50:14.010] [ 1.309172] SMP: stopping secondary CPUs
[2025-01-07 19:50:14.023] [ 1.309180] Kernel Offset: 0x3224c9e00000 from 0xffff800080000000
[2025-01-07 19:50:14.023] [ 1.309183] PHYS_OFFSET: 0xffffdebf00000000
[2025-01-07 19:50:14.023] [ 1.309185] CPU features: 0x0,00000009,00020000,1000421b
[2025-01-07 19:50:14.023] [ 1.309190] Memory Limit: none
[2025-01-07 19:50:14.023] [ 1.561519] ---[ end Kernel panic - not syncing: Asynchronous SError Interrupt ]---
910 次查看
takeshi100
I made a mistake to fix imx8mm_bl31_setup.c.
■ mistake
    RDC_PDAPn(RDC_PDAP_UART4, D0R | D1W)
■ correct
    RDC_PDAPn(RDC_PDAP_UART4, D0R | D0W),
911 次查看
takeshi100
■ mistake
■ correct
%3CLINGO-SUB%20id%3D%22lingo-sub-2023656%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%88%91%E6%83%B3%E5%9C%A8imx8mm%E4%B8%AD%E4%BD%BF%E7%94%A8uart4%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2023656%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%A0%B9%E6%8D%AE%E4%BB%A5%E4%B8%8B%E7%BD%91%E7%AB%99%EF%BC%8C%E6%88%91%E4%BF%AE%E5%A4%8D%E4%BA%86%E8%AE%BE%E5%A4%87%E6%A0%91%E5%92%8Cimx8mm_bl31_setup.c%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%86%E6%98%AF%EF%BC%8C%E5%86%85%E6%A0%B8%E6%81%90%E6%85%8C%E4%BB%8D%E7%84%B6%E5%8F%91%E7%94%9F%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E8%BF%98%E5%BA%94%E8%AF%A5%E5%81%9A%E4%BA%9B%E4%BB%80%E4%B9%88%E5%90%97%EF%BC%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%20%E2%96%A0%20%E7%BD%91%E7%AB%99%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FHow-to-use-UART4-on-iMX8M-from-Linux-User-Space%2Fta-p%2F1762038%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fi-MX-Processors-Knowledge-Base%2FHow-to-use-UART4-on-iMX8M-from-Linux-User-Space%2Fta-p%2F1762038%3C%2FA%3E%3C%2FP%3E%3CP%3E%E2%96%A0%20%E6%97%A5%E5%BF%97%3C%2FP%3E%3CP%3E%5B2025-01-07%2019%3A50%3A13.705%5D%5B0.126548%5D%E6%80%BB%E7%BA%BF%E9%A2%91%E7%8E%87%E9%A9%B1%E5%8A%A8%E6%A8%A1%E5%9D%97%E5%B7%B2%E5%8A%A0%E8%BD%BD%3CBR%20%2F%3E%5B2025-01-07%2019%3A50%3A13.705%5D%5B%200.137182%5D%20%E4%B8%B2%E8%A1%8C%EF%BC%9A8250%2F16550%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C4%20%E4%B8%AA%E7%AB%AF%E5%8F%A3%EF%BC%8C%E5%90%AF%E7%94%A8%20IRQ%20%E5%85%B1%E4%BA%AB%3CBR%20%2F%3E%5B2025-01-07%2019%3A50%3A13.705%5D%5B0.139992%5D30860000.%E5%BA%8F%E5%88%97%E5%8F%B7%EF%BC%9Attymxc0%20%E4%BD%8D%E4%BA%8E%20MMIO%200x30860000%20(irq%20%3D%2015%2C%20base_baud%20%3D%205000000)%20%E6%98%AF%20IMX%3CBR%20%2F%3E%20%5B2025-01-07%2019%3A50%3A13.705%5D%5B0.140121%5D%E4%B8%B2%E8%A1%8Cserial0%3Atty%E7%AB%AF%E5%8F%A3ttymxc0%E5%B7%B2%E6%B3%A8%E5%86%8C%3CBR%20%2F%3E%5B2025-01-07%2019%3A50%3A13.706%5D%5B0.140547%5D30890000.%E5%BA%8F%E5%88%97%E5%8F%B7%EF%BC%9Attymxc1%20%E4%BD%8D%E4%BA%8E%20MMIO%200x30890000%20(irq%20%3D%2016%2C%20base_baud%20%3D%201500000)%20%E6%98%AF%20IMX%3CBR%20%2F%3E%20%5B2025-01-07%2019%3A50%3A13.722%5D%5B0.140585%5Dprintk%3A%E6%8E%A7%E5%88%B6%E5%8F%B0%5Bttymxc1%5D%E5%B7%B2%E5%90%AF%E7%94%A8%3CBR%20%2F%3E%5B2025-01-07%2019%3A50%3A13.960%5D%5B1.308725%5DCPU3%E4%B8%8A%E7%9A%84SError%E4%B8%AD%E6%96%AD%EF%BC%8C%E4%BB%A3%E7%A0%810x00000000bf000002%E2%80%94%E2%80%94SError%3CBR%20%2F%3E%20%5B2025-01-07%2019%3A50%3A13.960%5D%5B1.308737%5D%20CPU%3A%203%20PID%3A%201%20%E9%80%9A%E4%BF%A1%3A%20swapper%2F0%20%E6%9C%AA%E5%8F%97%E6%B1%A1%E6%9F%93%206.6.23-lts-next-gd490f49646f0-dirty%231%3CBR%20%2F%3E%20%5B2025-01-07%2019%3A50%3A13.960%5D%5B1.308744%5D%E7%A1%AC%E4%BB%B6%E5%90%8D%E7%A7%B0%EF%BC%9AFSL%20i.MX8MM%20EVK%E6%9D%BF%EF%BC%88DT%EF%BC%89%3CBR%20%2F%3E%20%5B2025-01-07%2019%3A50%3A13.960%5D%5B1.308747%5Dpstate%EF%BC%9A60000005%EF%BC%88nZCv%20daif-PAN-UAO-TCO-DIT-SSBS%20BTYPE%3D--%EF%BC%89%3CBR%20%2F%3E%20%5B2025-01-07%2019%3A50%3A13.960%5D%5B1.308754%5DPC%EF%BC%9AIMX_UART_%E6%8E%A2%E9%92%88%2B0x3E4%2F0x980%3CBR%20%2F%3E%20%5B2025-01-07%2019%3A50%3A13.960%5D%5B1.308771%5Dlr%3Aimx_uart_%E6%8E%A2%E9%92%88%2B0x380%2F0x980%3CBR%20%2F%3E%20%5B2025-01-07%2019%3A50%3A13.960%5D%5B1.308783%5Dsp%3Affff80008003bb30%3CBR%20%2F%3E%20%5B2025-01-07%2019%3A50%3A13.960%5D%5B1.308785%5Dx29%EF%BC%9Affff80008003bb50%20x28%EF%BC%9A0000000000000000%20x27%EF%BC%9Affffb2254bc76068%3CBR%20%2F%3E%20%5B2025-01-07%2019%3A50%3A13.960%5D%5B1.308799%5Dx26%EF%BC%9Affff2141444fd0c0%20x25%EF%BC%9A0000000000000011%20x24%EF%BC%9A00000000fffffffa%3CBR%20%2F%3E%20%5B2025-01-07%2019%3A50%3A13.960%5D%5B1.308809%5Dx23%3Affff21414410bc10%20x22%3A00000000fffffffa%20x21%3Affff21414410bc00%3CBR%20%2F%3E%20%5B2025-01-07%2019%3A50%3A13.960%5D%5B1.308821%5Dx20%EF%BC%9A0000000000000000%20x19%EF%BC%9Affff2141448e8080%20x18%EF%BC%9Affffffffffffffff%3CBR%20%2F%3E%20%5B2025-01-07%2019%3A50%3A13.973%5D%5B1.308832%5Dx17%3A1fffe428288813e1%20x16%3A000000000000000%20x15%3Affff80008003b4d0%3CBR%20%2F%3E%20%5B2025-01-07%2019%3A50%3A13.973%5D%5B1.308844%5Dx14%3Affffffffffffffff%20x13%3A000000000000018%20x12%3A0101010101010101%3CBR%20%2F%3E%20%5B2025-01-07%2019%3A50%3A13.973%5D%5B1.308854%5Dx11%EF%BC%9A7f7f7f7f7f7f7f7f%20x10%EF%BC%9Affffb6254db29d2f%20x9%EF%BC%9A0000000000000028%3CBR%20%2F%3E%20%5B2025-01-07%2019%3A50%3A13.973%5D%5B1.308865%5Dx8%EF%BC%9Affff2141444fd180%20x7%EF%BC%9A0000000000000000%20x6%EF%BC%9A000000000080e3ec%3CBR%20%2F%3E%20%5B2025-01-07%2019%3A50%3A13.973%5D%5B1.308875%5Dx5%EF%BC%9A0000000000000000%20x4%EF%BC%9A0000000000000000%20x3%EF%BC%9A0000000000000000%3CBR%20%2F%3E%20%5B2025-01-07%2019%3A50%3A13.973%5D%5B1.308886%5Dx2%3A00000000ffff4ddf%20x1%3Affff800080570080%20x0%3A0000000000000001%3CBR%20%2F%3E%20%5B2025-01-07%2019%3A50%3A13.973%5D%5B1.308901%5D%20%E5%86%85%E6%A0%B8%E5%B4%A9%E6%BA%83%20-%20%E6%9C%AA%E5%90%8C%E6%AD%A5%EF%BC%9A%E5%BC%82%E6%AD%A5%20SError%20%E4%B8%AD%E6%96%AD%3CBR%20%2F%3E%5B2025-01-07%2019%3A50%3A13.973%5D%5B1.308904%5D%20CPU%EF%BC%9A3%20PID%EF%BC%9A1%20%E9%80%9A%E4%BF%A1%EF%BC%9A%E4%BA%A4%E6%8D%A2%E5%99%A8%2F0%20%E6%9C%AA%E5%8F%97%E6%B1%A1%E6%9F%93%206.6.23-lts-next-gd490f49646f0-dirty%231%3CBR%20%2F%3E%20%5B2025-01-07%2019%3A50%3A13.973%5D%5B1.308909%5D%E7%A1%AC%E4%BB%B6%E5%90%8D%E7%A7%B0%EF%BC%9AFSL%20i.MX8MM%20EVK%E6%9D%BF%EF%BC%88DT%EF%BC%89%3CBR%20%2F%3E%20%5B2025-01-07%2019%3A50%3A13.990%5D%5B1.308913%5D%E5%91%BC%E5%8F%AB%E8%B7%9F%E8%B8%AA%EF%BC%9A%3CBR%20%2F%3E%20%5B2025-01-07%2019%3A50%3A13.990%5D%5B1.308915%5D%E8%BD%AC%E5%82%A8%E5%9B%9E%E6%BA%AF%2B0x94%2F0x114%3CBR%20%2F%3E%20%5B2025-01-07%2019%3A50%3A13.990%5D%5B1.308929%5D%E6%98%BE%E7%A4%BA%E5%A0%86%E6%A0%88%2B0x18%2F0x24%3CBR%20%2F%3E%20%5B2025-01-07%2019%3A50%3A13.990%5D%5B1.308940%5D%E8%BD%AC%E5%82%A8%E5%A0%86%E6%A0%88%E7%BA%A7%E5%88%AB%2B0x48%2F0x60%3CBR%20%2F%3E%20%5B2025-01-07%2019%3A50%3A13.990%5D%5B1.308955%5D%E8%BD%AC%E5%82%A8%E5%A0%86%E6%A0%88%2B0x18%2F0x24%3CBR%20%2F%3E%20%5B2025-01-07%2019%3A50%3A13.990%5D%5B1.308966%5D%E6%81%90%E6%85%8C%2B0x31c%2F0x378%3CBR%20%2F%3E%20%5B2025-01-07%2019%3A50%3A13.990%5D%5B1.308975%5Dnmi_%E6%81%90%E6%85%8C%2B0x8c%2F0x90%3CBR%20%2F%3E%20%5B2025-01-07%2019%3A50%3A13.990%5D%5B1.308984%5Darm64_serror_panic%2B0x6c%2F0x78%3CBR%20%2F%3E%20%5B2025-01-07%2019%3A50%3A13.990%5D%5B1.308993%5Ddo_serror%2B0x3c%2F0x70%3CBR%20%2F%3E%20%5B2025-01-07%2019%3A50%3A13.990%5D%5B1.308998%5Del1h_64_%E9%94%99%E8%AF%AF_%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%2B0x30%2F0x48%3CBR%20%2F%3E%20%5B2025-01-07%2019%3A50%3A13.990%5D%5B1.309007%5Del1h_64_%E9%94%99%E8%AF%AF%2B0x64%2F0x68%3CBR%20%2F%3E%20%5B2025-01-07%2019%3A50%3A13.990%5D%5B1.309012%5Dimx_uart_%E6%8E%A2%E9%92%88%2B0x3e4%2F0x980%3CBR%20%2F%3E%20%5B2025-01-07%2019%3A50%3A13.990%5D%5B1.309021%5D%E5%B9%B3%E5%8F%B0%E6%8E%A2%E6%B5%8B%2B0x68%2F0xc4%3CBR%20%2F%3E%20%5B2025-01-07%2019%3A50%3A13.990%5D%5B1.309035%5D%E7%9C%9F%E6%AD%A3%E6%8E%A2%E6%B5%8B%2B0x188%2F0x3c4%3CBR%20%2F%3E%20%5B2025-01-07%2019%3A50%3A14.005%5D%5B1.309044%5D__driver_probe_device%2B0x7c%2F0x16c%3CBR%20%2F%3E%20%5B2025-01-07%2019%3A50%3A14.005%5D%5B1.309054%5D%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%8E%A2%E6%B5%8B%E8%AE%BE%E5%A4%87%2B0x3c%2F0x110%3CBR%20%2F%3E%20%5B2025-01-07%2019%3A50%3A14.005%5D%5B1.309066%5D__driver_attach%2B0xf0%2F0x1f8%3CBR%20%2F%3E%20%5B2025-01-07%2019%3A50%3A14.005%5D%5B1.309077%5D%E6%AF%8F%E4%B8%AA%E8%AE%BE%E5%A4%87%E6%80%BB%E7%BA%BF%2B0x7c%2F0xdc%3CBR%20%2F%3E%20%5B2025-01-07%2019%3A50%3A14.005%5D%5B1.309086%5D%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F_attach%2B0x24%2F0x30%3CBR%20%2F%3E%20%5B2025-01-07%2019%3A50%3A14.005%5D%5B1.309095%5D%E6%80%BB%E7%BA%BF%E6%B7%BB%E5%8A%A0%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%2B0x114%2F0x224%3CBR%20%2F%3E%20%5B2025-01-07%2019%3A50%3A14.005%5D%5B1.309104%5D%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F_%E5%AF%84%E5%AD%98%E5%99%A8%2B0x5c%2F0x124%3CBR%20%2F%3E%20%5B2025-01-07%2019%3A50%3A14.005%5D%5B1.309117%5D__%E5%B9%B3%E5%8F%B0_%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F_%E5%AF%84%E5%AD%98%E5%99%A8%2B0x28%2F0x34%3CBR%20%2F%3E%20%5B2025-01-07%2019%3A50%3A14.005%5D%5B1.309130%5Dimx_uart_init%2B0x54%2F0x7c%3CBR%20%2F%3E%20%5B2025-01-07%2019%3A50%3A14.005%5D%5B1.309140%5D%E6%89%A7%E8%A1%8C%E4%B8%80%E6%AC%A1%E5%88%9D%E5%A7%8B%E5%8C%96%E8%B0%83%E7%94%A8%2B0x80%2F0x1c8%3CBR%20%2F%3E%20%5B2025-01-07%2019%3A50%3A14.010%5D%5B1.309147%5D%E5%86%85%E6%A0%B8_init_freeable%2B0x1bc%2F0x284%3CBR%20%2F%3E%20%5B2025-01-07%2019%3A50%3A14.010%5D%5B1.309157%5D%E5%86%85%E6%A0%B8%E5%88%9D%E5%A7%8B%E5%8C%96%2B0x24%2F0x1dc%3CBR%20%2F%3E%20%5B2025-01-07%2019%3A50%3A14.010%5D%5B1.309163%5D%E4%BB%8E_fork%2B0x10%2F0x20%E8%BF%94%E5%9B%9E%3CBR%20%2F%3E%5B2025-01-07%2019%3A50%3A14.010%5D%5B1.309172%5DSMP%3A%E5%81%9C%E6%AD%A2%E8%BE%85%E5%8A%A9CPU%3CBR%20%2F%3E%20%5B2025-01-07%2019%3A50%3A14.023%5D%5B1.309180%5D%E5%86%85%E6%A0%B8%E5%81%8F%E7%A7%BB%E9%87%8F%EF%BC%9A0x3224c9e00000%20%E6%9D%A5%E8%87%AA%200xffff800080000000%3CBR%20%2F%3E%20%5B2025-01-07%2019%3A50%3A14.023%5D%5B1.309183%5D%E7%89%A9%E7%90%86%E5%81%8F%E7%A7%BB%EF%BC%9A0xffffdebf00000000%3CBR%20%2F%3E%20%5B2025-01-07%2019%3A50%3A14.023%5D%5B1.309185%5DCPU%E5%8A%9F%E8%83%BD%EF%BC%9A0x0%2C00000009%2C00020000%2C1000421b%3CBR%20%2F%3E%20%5B2025-01-07%2019%3A50%3A14.023%5D%5B1.309190%5D%E5%86%85%E5%AD%98%E9%99%90%E5%88%B6%EF%BC%9A%E6%97%A0%3CBR%20%2F%3E%5B2025-01-07%2019%3A50%3A14.023%5D%5B%201.561519%5D%20---%5B%E7%BB%93%E6%9D%9F%E5%86%85%E6%A0%B8%E6%81%90%E6%85%8C%20-%20%E6%9C%AA%E5%90%8C%E6%AD%A5%EF%BC%9A%E5%BC%82%E6%AD%A5%20SError%20%E4%B8%AD%E6%96%AD%5D---%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2023875%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E6%88%91%E6%83%B3%E5%9C%A8imx8mm%E4%B8%AD%E4%BD%BF%E7%94%A8uart4%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2023875%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E7%8A%AF%E4%BA%86%E4%B8%80%E4%B8%AA%E9%94%99%E8%AF%AF%E6%9D%A5%E4%BF%AE%E5%A4%8D%3CSPAN%3Eimx8mm_bl31_setup.c%3C%2FSPAN%3E%20%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%E2%96%A0%20%E9%94%99%E8%AF%AF%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3ERDC_PDAPn%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%88RDC_PDAP_UART4%EF%BC%8CD0R%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%20%3CSPAN%3ED1W%EF%BC%89%3CBR%20%2F%3E%20%E2%96%A0%20%E6%AD%A3%E7%A1%AE%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3ERDC_PDAPn%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%88RDC_PDAP_UART4%EF%BC%8CD0R%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3C%2FSPAN%3E%20%3CSPAN%3ED0W%EF%BC%89%EF%BC%8C%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
