I.mx8m mini add new mipi lcd panel
1603354597
hi,
   I got a imx8mm evk board and a panel (IMX8_DSI_OLED1).
Now, I plan to use a new mipi lcd panel (ZJJ05005-LCM) to display instead of IMX8_DSI_OLED1,
ZJJ05005-LCM's driver IC is NT35523.
   What should I do? I have some confusion about it.
   1, Is there any drivers can be used directly or be modified for my mipi LCD panel in NXP Android 9 open sourse code? And where is it?
   2, What should I modify for  fsl-imx8mm-evk.dts? Because the default panel is oled and its dts configure is different with LCD's.
wong
e_kotsarev
I have similar to NT35523 IC -- nt35521s but this IC has custom manufactor hex table for init. Do you have hex table for NT35523?
e_kotsarev
iirc you can take rm67191 driver as reference.
1603354597
hi
   Thank you for your reply. Do you have the example about rm67191 dts.
wong
Rita_Wang
