My command line is:
Kernel command line: noinitrd console=ttyAM0,115200 root=/dev/mmcblk0p3 rw rootwait ip=none gpmi
this is by default set in (2.6.35.3 kernel )
Other thing what i noticed is that NAND and SD1 will be sharing pins, So how should i configure them by disabling NAND pins...
Sinan Emre Kutlu said:I think it depends on your kernel command line
