Dear technical support:
mx8_v4l2_cap_drm.c,
I removed part of the DRM code, kept the v4l2 code, compiled my own mx8_v4l2_cap_drm.out with aarch64-linux-gnu-gcc and run it to ioctl(fd_v4l, VIDIOC_S_PARM, &parm). The return value is -1, and the mx8_v4l2_cap_drm.out provided by the system can be normal Run, why? Thank you!
已解决! 转到解答。
Hi 783435100
one can try to debug it using Video for Linux API documentation and error codes description :
https://siqueira.tech/doc/drm/userspace-api/media/v4l/vidioc-g-parm.html#c.VIDIOC_S_PARM
https://siqueira.tech/doc/drm/userspace-api/media/gen-errors.html#id1
Hi 783435100
