Dear technical support:
mx8_v4l2_cap_drm.c,
I removed part of the DRM code, kept the v4l2 code, compiled my own mx8_v4l2_cap_drm.out with aarch64-linux-gnu-gcc and run it to ioctl(fd_v4l, VIDIOC_S_PARM, &parm). The return value is -1, and the mx8_v4l2_cap_drm.out provided by the system can be normal Run, why? Thank you!
