I can't read Figure 11-44 of i.MX8MM reference manual
yasunori_suzuki
I can't read Figure 11-44.
Because it's too messy words.
Could you provide the information about  Figure 11-44.
b36401
Ping is a packet in USB protocol layer that checks if endpoint can accept data.
And noted table describes a behavior of USB bus controller in cases of acknowledge and negative acknowledge.
yasunori_suzuki
I want to know this configuration space layout(ex. offset addresses and configuration space contents).
If you have that information, you could teach me?
