I.MX8M PLUS and I.MX8QuadMax kits for using tensorflow-hub platform.
已解决
跳至解决方案
884 次查看
Param21
How can i use tensorflow-hub platform on both of these boards. I am utilizing a deep learning model which is imported in the project through tensorflow-hub API. The tensorflow-Hub version that i am using in my project is tensorflow-hub==0.16.1.
Please provide detailed procedure to use tensorflow hub on both of these kits.
1 解答
860 次查看
Zhiming_Liu
Please refer below guide. There is no support for tensorflow-hub
https://www.nxp.com/docs/en/user-guide/IMX-MACHINE-LEARNING-UG.pdf
Best Regards
Zhiming
在原帖中查看解决方案
1 回复
861 次查看
Zhiming_Liu
Best Regards
Zhiming
