Hello Community,
unfortunately i cannot find much helpful details about some pins in the "Datasheet" or "Reference Manual".
For example i cannot find the information if a signal is "high"- or "low"-active, see screenshots:
I have to look after schematics of the "Eval-Board" to see any negations. Maybe i need any other papers
to solve this problem ? Please can anyone help and show me the right way out ? :-)
Thanks and best regards.
Solved! Go to Solution.
Hi Walter
"_B" means active low signal "Bar". For ddr signals one cam look at DDRs datasheet
or ddr specifications. RTC_XTALI,XTALO are oscillator analog signals, meaning
of "active" is not applicable for them.
That sounds conclusive.
Thx and BR
Hi Walter
