I.MX6 Sololite LCD_ENABLE define
bpmmaster
I.MX6 Sololite :In Reference Manual and datasheet , I can not find the description for " LCD_Enable ".
I don't know if it's the same as " LCD_DRDY" or " LCD_DE", is this the synchronous
control signal with "HSYNC" and "VSYNC"?
not only a On/OFF control?
Because I need converter the parallel  LCD signals to  LVDS  interface,
Yuri
LCD_ENABLE signal enables the data to be shifted to the display. When disabled, the data is invalid
Please look at ENABLE signal on Figure 21-13 (DOTCLK protocol with programmable parameters)
of IMX6SLRM (Rev. 1, 04/2013)
Yuri
bpmmaster
thanks, Mubin.
