I use one sound card, configuration using SSI2, I2S as the master, AUD3 audio output, AUD4 Bluetooth, AUD5 MIC input. Now the problem is that AUD3 and AUD4 need to output 44.1K LRCK, AUD5 need to output 48K LRCK, after I change the LRCK, AUD3, AUD4, AUD5 LRCK change at the same time, and the clock is the same. Can I modify each AUD and output different LRCK at the same time?
已解决! 转到解答。
not sorry. AUDMUX can not change signal frequency.
