I.MX6 Board download Linux Firmware an error occurred
1,314 次查看
tombruce
this board had used and worked normally for one year, but recently it can not work .our user say"before it is bad ,they just  did some keystrokes operations。So we take it back ,find it can not start and download Linux Firmware an error occurred,we want to  analyze the cause of the error.
Please give me some suggestions .
Best  Regards!
Bruce
The following is error message:
U-Boot 2009.08-svn (12月 04 2015 - 18:30:13)
CPU: Freescale i.MX6 family TO1.5 at 792 MHz
Thermal sensor with ratio = 178
Temperature: 25 C, calibration data 0x5694e269
mx6q pll1: 792MHz
mx6q pll2: 528MHz
mx6q pll3: 480MHz
mx6q pll8: 50MHz
ipg clock : 66000000Hz
ipg per clock : 66000000Hz
uart clock : 80000000Hz
cspi clock : 60000000Hz
ahb clock : 132000000Hz
axi clock : 264000000Hz
emi_slow clock: 132000000Hz
ddr clock : 528000000Hz
usdhc1 clock : 198000000Hz
usdhc2 clock : 198000000Hz
usdhc3 clock : 198000000Hz
usdhc4 clock : 198000000Hz
nfc clock : 24000000Hz
Board: MYIMX6EK200, i.MX6Q.
Boot Device: SPI NOR
I2C: ready
DRAM: 1 GB
MMC: FSL_USDHC: 0,FSL_USDHC: 1,FSL_USDHC: 2
Using default environment
In: serial
Out: serial
Err: serial
Net: got MAC address from IIM: 1c:87:76:51:51:83
FEC0 [PRIME]
Hit any key to stop autoboot: 0
## Booting kernel from Legacy Image at 10800000 ...
Image Name: Linux-3.0.35
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 3296224 Bytes = 3.1 MB
Load Address: 10008000
Entry Point: 10008000
Verifying Checksum ... OK
## Loading init Ramdisk from Legacy Image at 10c00000 ...
Image Name: uboot initramfs rootfs
Image Type: ARM Linux RAMDisk Image (gzip compressed)
Data Size: 4537478 Bytes = 4.3 MB
Load Address: 00000000
Entry Point: 00000000
Loading Kernel Image ... OK
OK
Starting kernel ...
Linux version 3.0.35 (tang@u12045-serv) (gcc version 4.6.2 20110630 (prerelease) (Freescale MAD -- Linaro 2011.07 -- Built at 2011/08/10 09:20) ) #4 SMP PREEMPT Wed Au g 3 16:08:57 CST 2016
CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d
CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: i.MX6 Evaluation Kit
Memory policy: ECC disabled, Data cache writealloc
CPU identified as i.MX6Q, silicon rev 1.5
PERCPU: Embedded 7 pages/cpu @8c008000 s5184 r8192 d15296 u32768
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 227328
Kernel command line: console=ttymxc0,115200 rdinit=/linuxrc enable_wait_mode=off
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 640MB 256MB = 896MB total
Memory: 897304k/897304k available, 151272k reserved, 0K highmem
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
DMA : 0xf4600000 - 0xffe00000 ( 184 MB)
vmalloc : 0xc0800000 - 0xf2000000 ( 792 MB)
lowmem : 0x80000000 - 0xc0000000 (1024 MB)
pkmap : 0x7fe00000 - 0x80000000 ( 2 MB)
modules : 0x7f000000 - 0x7fe00000 ( 14 MB)
.init : 0x80008000 - 0x8003e000 ( 216 kB)
.text : 0x8003e000 - 0x805f81e0 (5865 kB)
.data : 0x805fa000 - 0x8064d000 ( 332 kB)
.bss : 0x8064d024 - 0x80678974 ( 175 kB)
SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
Preemptible hierarchical RCU implementation.
NR_IRQS:624
MXC GPIO hardware
sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 1431655ms
arm_max_freq=1GHz
MXC_Early serial console at MMIO 0x2020000 (options '115200')
bootconsole [ttymxc0] enabled
Console: colour dummy device 80x30
Calibrating delay loop... 1581.05 BogoMIPS (lpj=7905280)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
CPU1: Booted secondary processor
CPU2: Booted secondary processor
CPU3: Booted secondary processor
Brought up 4 CPUs
SMP: Total of 4 processors activated (6324.22 BogoMIPS).
print_constraints: dummy:
NET: Registered protocol family 16
print_constraints: vddpu: 725 <--> 1300 mV at 700 mV fast normal
print_constraints: vddcore: 725 <--> 1300 mV at 1150 mV fast normal
print_constraints: vddsoc: 725 <--> 1300 mV at 1200 mV fast normal
print_constraints: vdd2p5: 2000 <--> 2775 mV at 2400 mV fast normal
print_constraints: vdd1p1: 800 <--> 1400 mV at 1100 mV fast normal
print_constraints: vdd3p0: 2625 <--> 3400 mV at 3000 mV fast normal
Wait for CR ACK error!
sata phy rx_pll is stable!
No AHCI save PWR: PDDQ enabled
hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
hw-breakpoint: 1 breakpoint(s) reserved for watchpoint single-step.
hw-breakpoint: maximum watchpoint size is 4 bytes.
L310 cache controller enabled
l2x0: 16 ways, CACHE_ID 0x410000c7, AUX_CTRL 0x32070000, Cache size: 1048576 B
bio: create slab <bio-0> at 0
mxs-dma mxs-dma-apbh: initialized
print_constraints: SPKVDD: 4200 mV
print_constraints: 1_8V: 1800 mV
print_constraints: MICVDD: 3300 mV
print_constraints: vmmc: 3300 mV
vgaarb: loaded
SCSI subsystem initialized
spi_imx imx6q-ecspi.0: probed
spi_imx imx6q-ecspi.1: probed
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
imx-ipuv3 imx-ipuv3.0: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
imx-ipuv3 imx-ipuv3.1: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
Advanced Linux Sound Architecture Driver Version 1.0.24.
Bluetooth: Core ver 2.16
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP socket layer initialized
Bluetooth: SCO socket layer initialized
max17135 2-0048: PMIC MAX17135 for eInk display
i2c-core: driver [max17135] using legacy suspend method
i2c-core: driver [max17135] using legacy resume method
Switching to clocksource mxc_timer1
Clockevents: could not switch to one-shot mode:
Clockevents: could not switch to one-shot mode: dummy_timer is not functional.
Could not switch to high resolution mode on CPU 2
Could not switch to high resolution mode on CPU 3
Could not switch to high resolution mode on CPU 1
Could not switch to high resolution mode on CPU 0
NET: Registered protocol family 2
IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
TCP: Hash tables configured (established 131072 bind 65536)
TCP reno registered
UDP hash table entries: 512 (order: 2, 16384 bytes)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
Unpacking initramfs...
Freeing initrd memory: 4428K
PMU: registered new PMU device of type 0
Static Power Management for Freescale i.MX6
wait mode is disabled for i.MX6
cpaddr = 0 suspend_iram_base=f2900000
PM driver module loaded
iMX6 PCIe PCIe RC mode imx_pcie_pltfm_probe entering.
PCIE: imx_pcie_pltfm_probe start link up.
link up failed, DB_R0:0x00f76a00, DB_R1:0x08200000!
IMX PCIe port: link down!
IMX usb wakeup probe
cpu regulator mode:ldo_enable
i.MXC CPU frequency driver
JFFS2 version 2.2. (NAND) ? 2001-2006 Red Hat, Inc.
Unable to handle kernel paging request at virtual address 11a05003
pgd = bc150000
[11a05003] *pgd=00000000
Internal error: Oops: 5 [#1] PREEMPT SMP
Modules linked in:
CPU: 3 Not tainted (3.0.35 #4)
PC is at kmem_cache_alloc+0xd4/0x110
LR is at anon_vma_clone+0x34/0x14c
pc : [<800edb1c>] lr : [<800e1ed4>] psr: 60000093
sp : bc08dea0 ip : 00000001 fp : 000011cf
r10: 8060fcc0 r9 : 11a05003 r8 : 00000000
r7 : 0bfe4000 r6 : 11a05003 r5 : 00000200 r4 : bfff2200
r3 : bc08c000 r2 : 8060fcc0 r1 : 80040100 r0 : 20000013
Flags: nZCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment user
Control: 10c53c7d Table: 4c15004a DAC: 00000015
Process hotplug (pid: 647, stack limit = 0xbc08c2f0)
Stack: (0xbc08dea0 to 0xbc08e000)
dea0: 513a443c 800e1ed4 bc0a5444 bc0a52c0 bc0a57e8 2abab000 bc0a52c0 bfc17d98
dec0: bc0a5820 00000000 80659660 800e1ed4 0000001d bc0a52c0 bc0a57e8 2abab000
dee0: 8064e650 bfc15380 2abab000 00000000 00000000 800dd720 bc08dfb0 bc0a57e8
df00: bc08df8c bc0a57e8 bc08df8c 00000000 bd95c6f0 bff89780 08100875 800dfcb0
df20: 08100875 bd95c6f0 bff89780 0000001c 00000000 00000003 2abaa000 2ad4ffff
df40: 00000000 2ad50000 bfc15380 08100877 00000001 804781c4 00000001 2abab000
df60: 2abab000 bc08c000 00000005 00000000 bc08c000 00000000 7e9f3adc 800dfe1c
df80: 08100875 0002ab1b bffd2660 bc0a57e8 2abab560 00000018 2ab86724 0000007d
dfa0: 80044084 80043f00 2abab560 00000018 2abaa000 00001000 00000001 fffff000
dfc0: 2abab560 00000018 2ab86724 0000007d 0000b034 00000000 2ab86000 7e9f3adc
dfe0: 00000000 7e9f3a20 2ab913a8 2ab9c2bc 80000010 2abaa000 4fffc811 4fffcc11
[<800edb1c>] (kmem_cache_alloc+0xd4/0x110) from [<800e1ed4>] (anon_vma_clone+0x34/0x14c)
[<800e1ed4>] (anon_vma_clone+0x34/0x14c) from [<800dd720>] (__split_vma+0x78/0x1a8)
[<800dd720>] (__split_vma+0x78/0x1a8) from [<800dfcb0>] (mprotect_fixup+0x380/0x3d0)
[<800dfcb0>] (mprotect_fixup+0x380/0x3d0) from [<800dfe1c>] (sys_mprotect+0x11c/0x1a4)
[<800dfe1c>] (sys_mprotect+0x11c/0x1a4) from [<80043f00>] (ret_fast_syscall+0x0/0x30)
Code: 1affffe9 e5948014 e28bb004 e3a0c001 (e7968008)
---[ end trace 86e9e968b1d2b45f ]---
msgmni has been set to 1761
cryptodev: driver loaded.
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
pgd = bc06c000
mxc_sdc_fb mxc_sdc_fb.0: register mxc display driver ldb
_regulator_get: get() with no identifier
Internal error: Oops: 5 [#2] PREEMPT SMP
Modules linked in:
CPU: 3 Tainted: G D (3.0.35 #4)
LR is at anon_vma_prepare+0x2c/0x168
pc : [<800edb1c>] lr : [<800e1ba4>] psr: 60000193
sp : bc09ddb8 ip : 00000001 fp : 000012cf
r7 : 0bfe4000 r6 : 11a05003 r5 : 000000d0 r4 : bfff2200
r3 : bc09c000 r2 : 8060fcc0 r1 : 80040100 r0 : 20000113
Control: 10c53c7d Table: 4c06c04a DAC: 00000015
Process hotplug (pid: 668, stack limit = 0xbc09c2f0)
Stack: (0xbc09ddb8 to 0xbc09e000)
dda0: be0a5b28 800e1ba4
ddc0: bc09deb8 bc0a5630 00000000 2aba8000 80659660 bfc15040 bfc15040 bc0366a0
dde0: bfc1507c 800e1ba4 00100077 00000000 bc0a5630 2aba8000 2aba8000 bc06caa8
de00: bc0366a0 800dabf8 be08cfd0 800c1cec bc09de7c bc09def8 00000001 00000000
de20: 00000001 00000001 00000200 800fc198 001580a5 bc06c000 00000155 2aba8000
de40: bfc15040 bc0a5630 bc06caa8 00000001 bfc1507c 800daea8 bc06caa8 00000001
de60: ea308021 bfc15040 2aba8014 bc09dfb0 bc0a5630 bfcb6440 00000817 2aba8250
de80: bfc1507c 8004e528 2157f857 4ea853e8 28ad45bf ab64b41e eaa127fa c4ac5665
dea0: b11684b8 9f958c51 00000000 00000000 00000000 00000000 00000000 00000000
dec0: bebfbc70 97dd2adb 9ddf3357 b74f5a50 bc09c000 8003cc1c 0bfe4000 00001000
dee0: 8060fdf4 bc0a5284 bfc15040 00000817 80613518 2aba8014 bc09dfb0 00000000
df00: 00000000 2aba8250 00000009 8003e2f4 00000001 bc0a5630 00000000 800de43c
df20: bc0a517c 00000000 00000000 0002aba8 00000000 00000003 00000003 00000000
df40: 00000022 2aba8000 00000000 8022883c bfc15080 80000013 00000001 2aba8000
df60: 00000000 bc09c000 00000003 00001000 bc09c000 00000000 00000009 800deae4
df80: 00100077 0002aba8 00000002 ffffffff 00000000 00001000 000000c0 0000040f
dfa0: 00000007 2aba8000 2abb0958 80043e84 2aba8000 0000a149 0000000a 2aba8254
dfc0: 2abb0ef8 0000a149 2aba8000 2abb0958 00000000 00000000 2aba8250 00000009
dfe0: 2abb0958 7e8a44b0 2aba04a0 2ab95e9c 20000010 ffffffff 4fffc811 4fffcc11
[<800edb1c>] (kmem_cache_alloc+0xd4/0x110) from [<800e1ba4>] (anon_vma_prepare+0x2c/0x168)
[<800e1ba4>] (anon_vma_prepare+0x2c/0x168) from [<800dabf8>] (handle_pte_fault+0x500/0x6e4)
[<800dabf8>] (handle_pte_fault+0x500/0x6e4) from [<800daea8>] (handle_mm_fault+0xcc/0x16c)
[<800daea8>] (handle_mm_fault+0xcc/0x16c) from [<8004e528>] (do_page_fault+0x1b4/0x31c)
[<8004e528>] (do_page_fault+0x1b4/0x31c) from [<8003e2f4>] (do_DataAbort+0x34/0x9c)
[<8003e2f4>] (do_DataAbort+0x34/0x9c) from [<80043e84>] (ret_from_exception+0x0/0x10)
Exception stack(0xbc09dfb0 to 0xbc09dff8)
dfa0: 2aba8000 0000a149 0000000a 2aba8254
---[ end trace 86e9e968b1d2b460 ]---
imx-ipuv3 imx-ipuv3.1: IPU DMFC DP HIGH RESOLUTION: 1(0,1), 5B(2~5), 5F(6,7)
pgd = bc158000
Internal error: Oops: 5 [#3] PREEMPT SMP
Modules linked in:
sp : bc149db8 ip : 00000001 fp : 000012e7
r3 : bc148000 r2 : 8060fcc0 r1 : 80040100 r0 : 20000113
Control: 10c53c7d Table: 4c15804a DAC: 00000015
Process hotplug (pid: 681, stack limit = 0xbc1482f0)
Stack: (0xbc149db8 to 0xbc14a000)
9da0: be0a5a18 800e1ba4
9dc0: bc149eb8 bc0a5688 00000000 2ab54000 80659660 bfc151e0 bfc151e0 bc0b7550
9de0: bfc1521c 800e1ba4 00100077 00000000 bc0a5688 2ab54000 2ab54000 bc158aa8
9e00: bc0b7550 800dabf8 be08cfd0 800c1cec bc149e7c bc149ef8 00000001 00000000
9e20: 00000001 00000001 00000200 800fc198 001580a5 bc158000 00000155 2ab54000
9e40: bfc151e0 bc0a5688 bc158aa8 00000001 bfc1521c 800daea8 bc158aa8 00000001
9e60: 13172fb4 bfc151e0 2ab54014 bc149fb0 bc0a5688 bffbe440 00000817 2ab54250
9e80: bfc1521c 8004e528 53c44819 46891ecb 4302a0e1 a1165a20 eaa127fa c4ac5665
9ea0: c76229f7 9bde52d9 00000000 00000000 00000000 00000000 00000000 00000000
9ec0: bebfbc70 912df2c4 f124ad9d b54cc8ae bc148000 8003cc1c 0bfe4000 00001000
9ee0: 8060fdf4 bc0a564c bfc151e0 00000817 80613518 2ab54014 bc149fb0 00000000
9f00: 00000000 2ab54250 00000009 8003e2f4 00000001 bc0a5688 00000000 800de43c
9f20: bc0a5284 00000000 00000000 0002ab54 00000000 00000003 00000003 00000000
9f40: 00000022 2ab54000 00000000 8022883c bfc15220 80000013 00000001 2ab54000
9f60: 00000000 bc148000 00000003 00001000 bc148000 00000000 00000009 800deae4
9f80: 00100077 0002ab54 00000002 ffffffff 00000000 00001000 000000c0 0000040f
9fa0: 00000007 2ab54000 2ab17958 80043e84 2ab54000 0000a149 0000000a 2ab54254
9fc0: 2ab17ef8 0000a149 2ab54000 2ab17958 00000000 00000000 2ab54250 00000009
9fe0: 2ab17958 7e8b64a0 2ab074a0 2aafce9c 20000010 ffffffff 4ebc7d0f 63d37dfe
Exception stack(0xbc149fb0 to 0xbc149ff8)
9fa0: 2ab54000 0000a149 0000000a 2ab54254
---[ end trace 86e9e968b1d2b461 ]---
Console: switching to colour frame buffer device 128x48
mxc_sdc_fb mxc_sdc_fb.1: register mxc display driver ldb
mxc_sdc_fb mxc_sdc_fb.2: register mxc display driver lcd
mxc_sdc_fb mxc_sdc_fb.3: register mxc display driver ldb
mxc_sdc_fb mxc_sdc_fb.3: ipu1-di0 already in use
mxc_sdc_fb: probe of mxc_sdc_fb.3 failed with error -16
imx-sdma imx-sdma: loaded firmware 1.1
pgd = bc04c000
Internal error: Oops: 5 [#4] PREEMPT SMP
Modules linked in:
sp : bc127db8 ip : 00000001 fp : 000012ff
r3 : bc126000 r2 : 8060fcc0 r1 : 80040100 r0 : 20000113
Control: 10c53c7d Table: 4c04c04a DAC: 00000015
Process hotplug (pid: 689, stack limit = 0xbc1262f0)
Stack: (0xbc127db8 to 0xbc128000)
7da0: <4>r3 : bc144000 r2 : 8060fcc0 r1 : 80040100 r0 : 20000113
<4>Flags90>9f80: 00100077 0002ab6a 00000002 ffffffff 00000000 00001000 000000c0 0000040f
9fa0: 00000007 2ab6a000 2ab9d958 80043e84 2ab6a000000000 2aab1250 00000009
<0>3fe0: 2ab68958 7ee754b0 2ab584a0 2ab4de9c 20000010 ffffffff 4fffe821 4fffec21
Exception stack(0xbc123fb0 to 0xbc123ff8)
3fa0: 2aab1000 0000a149 0000000a 2aab1254
3fc0: 2ab68ef8 0000a149 2aab1000 2ab68958 00000000 00000000 2aab1250 00000009
---[ end trace 86e9e968b1d2b46f ]---
pgd = bc168000
Internal error: Oops: 5 [#18] PREEMPT SMP
Modules linked in:
sp : bc17bdb8 ip : 00000001 fp : 0000143f
r3 : bc17a000 r2 : 8060fcc0 r1 : 80040100 r0 : 20000113
Control: 10c53c7d Table: 4c16804a DAC: 00000015
Process hotplug (pid: 726, stack limit = 0xbc17a2f0)
Stack: (0xbc17bdb8 to 0xbc17c000)
bda0: bdad1110 800e1ba4
bdc0: bc17beb8 bc0a5630 00000000 2ab55000 80659660 bfc14680 bfc14680 bc02d554
bde0: bfc146bc 800e1ba4 00100077 00000000 bc0a5630 2ab55000 2ab55000 bc168aa8
be00: bc02d554 800dabf8 be08cfd0 800c1cec bc17be7c bc17bef8 00000001 00000000
be20: 00000001 00000001 00000200 800fc198 001580a5 bc168000 00000155 2ab55000
be40: bfc14680 bc0a5630 bc168aa8 00000001 bfc146bc 800daea8 bc168aa8 00000001
be60: fd0bcaf1 bfc14680 2ab55014 bc17bfb0 bc0a5630 bfd4e0a0 00000817 2ab55250
be80: bfc146bc 8004e528 839d5f75 1ef3564d e5c3234c b4d03fd8 eaa127fa c4ac5665
bea0: 08037419 870c907b 00000000 00000000 00000000 00000000 00000000 00000000
bec0: bebfbc70 4cc2a717 0b608520 0cf136c3 bc17a000 8003cc1c 0bfe4000 00001000
bee0: 8060fdf4 bc0a5c7c bfc14680 00000817 80613518 2ab55014 bc17bfb0 00000000
bf00: 00000000 2ab55250 00000009 8003e2f4 00000001 bc0a5630 00000000 800de43c
bf20: bc0a5284 00000000 00000000 0002ab55 00000000 00000003 00000003 00000000
bf40: 00000022 2ab55000 00000000 8022883c bfc146c0 80000013 00000001 2ab55000
bf60: 00000000 bc17a000 00000003 00001000 bc17a000 00000000 00000009 800deae4
bf80: 00100077 0002ab55 00000002 ffffffff 00000000 00001000 000000c0 0000040f
bfa0: 00000007 2ab55000 2aaf7958 80043e84 2ab55000 0000a149 0000000a 2ab55254
bfc0: 2aaf7ef8 0000a149 2ab55000 2aaf7958 00000000 00000000 2ab55250 00000009
bfe0: 2aaf7958 7e8fa4b0 2aae74a0 2aadce9c 20000010 ffffffff 4fffe821 4fffec21
Exception stack(0xbc17bfb0 to 0xbc17bff8)
bfa0: 2ab55000 0000a149 0000000a 2ab55254
---[ end trace 86e9e968b1d2b470 ]---
---[ end trace 86e9e968b1d2b46b ]---
pgd = bc0f8000
Internal error: Oops: 5 [#14] PREEMPT SMP
Modules linked in:
sp : bc16ddb8 ip : 00000001 fp : 000013df
r3 : bc16c000 r2 : 8060fcc0 r1 : 80040100 r0 : 20000113
Control: 10c53c7d Table: 4c0f804a DAC: 00000015
Process hotplug (pid: 718, stack limit = 0xbc16c2f0)
Stack: (0xbc16ddb8 to 0xbc16e000)
dda0: be01cf68 800e1ba4
ddc0: bc16deb8 bc0a5268 00000000 2ab46000 80659660 bfc14680 bfc14680 bc096518
dde0: bfc146bc 800e1ba4 00100077 00000000 bc0a5268 2ab46000 2ab46000 bc0f8aa8
de00: bc096518 800dabf8 be08cfd0 800c1cec bc16de7c bc16def8 00000001 00000000
de20: 00000001 00000001 00000200 800fc198 001580a5 bc0f8000 00000155 2ab46000
de40: bfc14680 bc0a5268 bc0f8aa8 00000001 bfc146bc 800daea8 bc0f8aa8 00000001
de60: 084dea3f bfc14680 2ab46014 bc16dfb0 bc0a5268 bfdacae0 00000817 2ab46250
de80: bfc146bc 8004e528 8c224260 9a4f0a0b f345dd15 fdf3d109 eaa127fa c4ac5665
dea0: 517f55b4 2db17bd6 00000000 00000000 00000000 00000000 00000000 00000000
dec0: bebfbc70 8c88fbdb ac9c6e79 9f725c71 bc16c000 8003cc1c 0bfe4000 00001000
dee0: 8060fdf4 bc0a564c bfc14680 00000817 80613518 2ab46014 bc16dfb0 00000000
df00: 00000000 2ab46250 00000009 8003e2f4 00000001 bc0a5268 00000000 800de43c
df20: bc0a50cc 00000000 00000000 0002ab46 00000000 00000003 00000003 00000000
df40: 00000022 2ab46000 00000000 8022883c bfc146c0 80000013 00000001 2ab46000
df60: 00000000 bc16c000 00000003 00001000 bc16c000 00000000 00000009 800deae4
df80: 00100077 0002ab46 00000002 ffffffff 00000000 00001000 000000c0 0000040f
dfa0: 00000007 2ab46000 2ab4e958 80043e84 2ab46000 0000a149 0000000a 2ab46254
dfc0: 2ab4eef8 0000a149 2ab46000 2ab4e958 00000000 00000000 2ab46250 00000009
dfe0: 2ab4e958 7e8524b0 2ab3e4a0 2ab33e9c 20000010 ffffffff 5d67775b d178c77b
Exception stack(0xbc16dfb0 to 0xbc16dff8)
dfa0: 2ab46000 0000a149 0000000a 2ab46254
---[ end trace 86e9e968b1d2b46c ]---
pgd = bc174000
Internal error: Oops: 5 [#15] PREEMPT SMP
Modules linked in:
sp : bc16fdb8 ip : 00000001 fp : 000013f7
r3 : bc16e000 r2 : 8060fcc0 r1 : 80040100 r0 : 20000113
Control: 10c53c7d Table: 4c17404a DAC: 00000015
Process hotplug (pid: 719, stack limit = 0xbc16e2f0)
Stack: (0xbc16fdb8 to 0xbc170000)
fda0: bdad23b8 800e1ba4
fdc0: bc16feb8 bc0a5c60 00000000 2aad5000 80659660 bfc151e0 bfc151e0 bc02c354
fde0: bfc1521c 800e1ba4 00100077 00000000 bc0a5c60 2aad5000 2aad5000 bc174aa8
fe00: bc02c354 800dabf8 be08cfd0 800c1cec bc16fe7c bc16fef8 00000001 00000000
fe20: 00000001 00000001 00000200 800fc198 001580a5 bc174000 00000155 2aad5000
fe40: bfc151e0 bc0a5c60 bc174aa8 00000001 bfc1521c 800daea8 bc174aa8 00000001
fe60: 22b9830a bfc151e0 2aad5014 bc16ffb0 bc0a5c60 bfdac3a0 00000817 2aad5250
fe80: bfc1521c 8004e528 3652b277 0e94da0f 744263b5 26c3aa26 eaa127fa c4ac5665
fea0: 21895e38 618b8865 00000000 00000000 00000000 00000000 00000000 00000000
fec0: bebfbc70 cc2b919e 627dddd7 474edcd2 bc16e000 8003cc1c 0bfe4000 00001000
fee0: 8060fdf4 00000001 bfc151e0 00000817 80613518 2aad5014 bc16ffb0 00000000
ff00: 00000000 2aad5250 00000009 8003e2f4 00000001 bc0a5c60 00000000 800de43c
ff20: bc0a517c 00000000 00000000 0002aad5 00000000 00000003 00000003 00000000
ff40: 00000022 2aad5000 00000000 8022883c bfc15220 80000013 00000001 2aad5000
ff60: 00000000 bc16e000 00000003 00001000 bc16e000 00000000 00000009 800deae4
ff80: 00100077 0002aad5 00000002 ffffffff 00000000 00001000 000000c0 0000040f
ffa0: 00000007 2aad5000 2ab18958 80043e84 2aad5000 0000a149 0000000a 2aad5254
ffc0: 2ab18ef8 0000a149 2aad5000 2ab18958 00000000 00000000 2aad5250 00000009
ffe0: 2ab18958 7ed394b0 2ab084a0 2aafde9c 20000010 ffffffff b7dfbced 3f73bfaf
Exception stack(0xbc16ffb0 to 0xbc16fff8)
ffa0: 2aad5000 0000a149 0000000a 2aad5254
---[ end trace 86e9e968b1d2b46d ]---
pgd = bc17c000
Internal error: Oops: 5 [#16] PREEMPT SMP
Modules linked in:
sp : bfc13db8 ip : 00000001 fp : 0000140f
r3 : bfc12000 r2 : 8060fcc0 r1 : 80040100 r0 : 20000113
Control: 10c53c7d Table: 4c17c04a DAC: 00000015
Process hotplug (pid: 721, stack limit = 0xbfc122f0)
Stack: (0xbfc13db8 to 0xbfc14000)
3da0: bdad2880 800e1ba4
3dc0: bfc13eb8 bc0a5688 00000000 2ab8e000 80659660 bfc14680 bfc14680 bc02c638
3de0: bfc146bc 800e1ba4 00100077 00000000 bc0a5688 2ab8e000 2ab8e000 bc17caa8
3e00: bc02c638 800dabf8 be08cfd0 800c1cec bfc13e7c bfc13ef8 00000001 00000000
3e20: 00000001 00000001 00000200 800fc198 001580a5 bc17c000 00000155 2ab8e000
3e40: bfc14680 bc0a5688 bc17caa8 00000001 bfc146bc 800daea8 bc17caa8 00000001
3e60: 2751907d bfc14680 2ab8e014 bfc13fb0 bc0a5688 bfd4c740 00000817 2ab8e250
3e80: bfc146bc 8004e528 c2b7bedd 3ee3177c 815f6cc9 e1978641 eaa127fa c4ac5665
3ea0: 8ba395c3 7528f7bf 00000000 00000000 00000000 00000000 00000000 00000000
3ec0: bebfbc70 135c45f0 c2c9e8a7 613843c3 bfc12000 8003cc1c 0bfe4000 00001000
3ee0: 8060fdf4 bc0a5124 bfc14680 00000817 80613518 2ab8e014 bfc13fb0 00000000
3f00: 00000000 2ab8e250 00000009 8003e2f4 00000001 bc0a5688 00000000 800de43c
3f20: bc0a5284 00000000 00000000 0002ab8e 00000000 00000003 00000003 00000000
3f40: 00000022 2ab8e000 00000000 8022883c bfc146c0 80000013 00000001 2ab8e000
3f60: 00000000 bfc12000 00000003 00001000 bfc12000 00000000 00000009 800deae4
3f80: 00100077 0002ab8e 00000002 ffffffff 00000000 00001000 000000c0 0000040f
3fa0: 00000007 2ab8e000 2ab89958 80043e84 2ab8e000 0000a149 0000000a 2ab8e254
3fc0: 2ab89ef8 0000a149 2ab8e000 2ab89958 00000000 00000000 2ab8e250 00000009
3fe0: 2ab89958 7ef1c4b0 2ab794a0 2ab6ee9c 20000010 ffffffff 4fffe821 4fffec21
Exception stack(0xbfc13fb0 to 0xbfc13ff8)
3fa0: 2ab8e000 0000a149 0000000a 2ab8e254
---[ end trace 86e9e968b1d2b46e ]---
pgd = bc174000
Internal error: Oops: 5 [#17] PREEMPT SMP
Modules linked in:
sp : bc123db8 ip : 00000001 fp : 00001427
r3 : bc122000 r2 : 8060fcc0 r1 : 80040100 r0 : 20000113
Process hotplug (pid: 724, stack limit = 0xbc1222f0)
Stack: (0xbc123db8 to 0xbc124000)
3da0: bdad2c38 800e1ba4
3dc0: bc123eb8 bc0a50b0 00000000 2aab1000 80659660 bfc151e0 bfc151e0 bc02c2c4
3de0: bfc1521c 800e1ba4 00100077 00000000 bc0a50b0 2aab1000 2aab1000 bc174aa8
3e00: bc02c2c4 800dabf8 be08cfd0 800c1cec bc123e7c bc123ef8 00000001 00000000
3e20: 00000001 00000001 00000200 800fc198 001580a5 bc174000 00000155 2aab1000
3e40: bfc151e0 bc0a50b0 bc174aa8 00000001 bfc1521c 800daea8 bc174aa8 00000001
3e60: a364905f bfc151e0 2aab1014 bc123fb0 bc0a50b0 bfd4f660 00000817 2aab1250
3e80: bfc1521c 8004e528 38d79e8b 5de141b8 48348148 08c72d7e eaa127fa c4ac5665
3ea0: 7e462a9e d3d569fb 00000000 00000000 00000000 00000000 00000000 00000000
3ec0: bebfbc70 f5f06aa1 e3d2869b 1f0fe684 bc122000 8003cc1c 0bfe4000 00001000
3ee0: 8060fdf4 00000001 bfc151e0 00000817 80613518 2aab1014 bc123fb0 00000000
3f00: 00000000 2aab1250 00000009 8003e2f4 00000001 bc0a50b0 00000000 800de43c
3f20: bc0a517c 00000000 00000000 0002aab1 00000000 00000003 00000003 00000000
3f40: 00000022 2aab1000 00000000 8022883c bfc15220 80000013 00000001 2aab1000
3f60: 00000000 bc122000 00000003 00001000 bc122000 00000000 00000009 800deae4
3f80: 00100077 0002aab1 00000002 ffffffff 00000000 00001000 000000c0 0000040f
ffe9 e59480o handle kernel paging request at virtual address 11a05003
pgd = bc180000
Internal error: >CPU: 3 Tainted: G D (3.0.35 #4)
LR is at anon_vma_prepare+0x2c/p : 00000001 fp : 00001547
r7 : 0bfe4000 r6 : 11a05003 r5 : 000000d0 r4 : bfffRQs off FIQs on Mode SVC_32 ISA ARM Segment user
Control: 10c53c7d Table: 4c1a404a DAC: 00000015
Process hotplug (pid: 764, stack limit = bda9d088 800e1ba4
3dc0: bc1d3eb8 bc0a50b0 00000000 2ab09000 80659660 bfc14680 bfc14680 bfddd424
3de0fddd618 800dabf8 be08cfd0 800c1cec bc203e7c bc203ef8 00000001 00000000
<0>3e20: 00000001 00000001 00000200 800fc198c146bc 800daea8 bc22caa8 00000001
<0>9e60: c04c950b bfc14680 2ab61014 bc209fb0 bc0a5160 bc1d5d00 00000817 2ab61250
9ea0: 1760f504 90ce574e 00000000 00000000 00000000 00000000 00000000 00000000
9ec0: bebfbc70 9e45b4f4 6edf20f5 a25b5373 bc228000 8003cc1c 0bfe4000 00001000
9ee0: 8060fdf4 bc0a5284 b0009 8003e2f4 00000001 bc0a50b0 00000000 800de43c
<0>bf20: bc0a5124 00000000 00000000 0002ab31 00000000 00000003 00000003 00000000
9f60: 00000000 bc2a8000 00000003 00001000 bc2a8000 00000000 00000009 800deae4
9f80: 00100077 0002aaf2 00000002 ffffffff 00000000 00001000 000000c0 0000040f
9fa0: 00000007 2aaf2000 2ab3c958 80043e84 2a000 00000000 2aafe250 00000009
<0>5fe0: 2ab78958 7ea95490 2ab684a0 2ab5de9c 20000010 ffffffff 4fffc811 4fffcc11
[<800edb1c>] (kmem_cache_alloc+0xd4/0x110) from 168) from [<800dabf8>] (handle_pte_fault+0x500/0x6e4)
[<800dabf8>] (handle_pte_fault+0x500/0x6e4) from [<800daea8>] (handl] (do_page_fault+0x1b4/0x31c)
[<8004e528>] (do_page_fault+0x1b4/0x31c) from [<8003e2f4>] (do_DataAbort+0x34/0x9c/0x10)
Exception stack(0xbc2f1fb0 to 0xbc2f1ff8)
1fa0: 2ab06000 0000a149 0000000a 2ab062<4>dfe0: 2ab2f958 7ee9d490 2ab1f4a0 2ab14e9c 20000010 ffffffff
---[ end trace 8605003
<1>pgd = bc390000
[11b05003] *pgd=00000000
Internal error: Oops: 5 [#95] PREEMPT SMP
Modulef85b6c
<4>Flags: nZcv IRQs on FIQs on Mode SVC_32 ISA ARM Seg2 666d6cb2 00000000 00000000 00000000 00000000 00000000 00000000
3ec0: bebfbc70 59ca37ef 6d7a5e47 517b2983 bc3a2000 8003cc1c 0bfe4000 00001000
3ee0: 8060fdf4 bc0a56a4 bfc14680 00000812f4 00000001 bc0a50b0 00000000 800de43c
1f20: bc0a517c 00000000 00000000 0002aace 00000000 00000003 00000003 00000000
1f40: 00000022 2aace000 00000000 8022883c bfc146c0 80000013 00000001 2aac0deae4
3f80: 00100077 0002aab9 00000002 ffffffff 00000000 00001000 000000c0 0000040f
3fa0: 00000007 2aab9000 2aaef958 80043e84 2aab9000 0000a149 0000000250 00000009
3fe0: 2ab89958 7ed81490 2ab794a0 2ab6ee9c 20000010 ffffffff 4fffe821 4fffec21
Exception stack(0xbc423fb0 to 0xbc423ff8)
3fa0: 2ab0b000 0000a149 0000000a 2ab0b254
3fc0: 2ab89ef8 0000a149 2ab0b000 2ab89958 00000000 00000000 2ab0b250 00000009
---[ end trace 86e9e968b1d2b4d6 ]---
---[ end trace 86e9e968b1d2b4d1 ]---
Unable to handle kernel paging request at virtual address 11b05003
pgd = bc428000
Internal error: Oops: 5 [#116] PREEMPT SMP
Modules linked in:
sp : bc3ebdb8 ip : 00000001 fp : 00001dcf
r10: 8060fcc0 r9 : 11b05003 r8 : 00000000
r7 : 0bfe4000 r6 : 11b05003 r5 : 000000d0 r4 : bfff2200
r3 : bc3ea000 r2 : 8060fcc0 r1 : 80040100 r0 : 20000113
Control: 10c53c7d Table: 4c42804a DAC: 00000015
Process hotplug (pid: 966, stack limit = 0xbc3ea2f0)
Stack: (0xbc3ebdb8 to 0xbc3ec000)
bda0: be03de58 800e1ba4
bdc0: bc3ebeb8 bc0a5108 00000000 2aaad000 80659660 bfc14680 bfc14680 bc34c2b4
bde0: bfc146bc 800e1ba4 00100077 00000000 bc0a5108 2aaad000 2aaad000 bc428aa8
be00: bc34c2b4 800dabf8 be08cfd0 800c1cec bc3ebe7c bc3ebef8 00000001 00000000
be20: 00000001 00000001 00000200 800fc198 001580a5 bc428000 00000155 2aaad000
be40: bfc14680 bc0a5108 bc428aa8 00000001 bfc146bc 800daea8 bc428aa8 00000001
be60: 83ee9c9d bfc14680 2aaad014 bc3ebfb0 bc0a5108 bc3f4ae0 00000817 2aaad250
be80: bfc146bc 8004e528 0b29ea33 dd8a2086 1d57e3a2 c9c9033e eaa127fa c4ac5665
bea0: da352776 0d3b7cd3 00000000 00000000 00000000 00000000 00000000 00000000
bec0: bebfbc70 e232f3f2 5b6dcfdf 66993597 bc3ea000 8003cc1c 0bfe4000 00001000
bee0: 8060fdf4 00000001 bfc14680 00000817 80613518 2aaad014 bc3ebfb0 00000000
bf00: 00000000 2aaad250 00000009 8003e2f4 00000001 bc0a5108 00000000 800de43c
bf20: bc0a5c7c 00000000 00000000 0002aaad 00000000 00000003 00000003 00000000
bf40: 00000022 2aaad000 00000000 8022883c bfc146c0 80000013 00000001 2aaad000
bf60: 00000000 bc3ea000 00000003 00001000 bc3ea000 00000000 00000009 800deae4
bf80: 00100077 0002aaad 00000002 ffffffff 00000000 00001000 000000c0 0000040f
bfa0: 00000007 2aaad000 2ab13958 80043e84 2aaad000 0000a149 0000000a 2aaad254
bfc0: 2ab13ef8 0000a149 2aaad000 2ab13958 00000000 00000000 2aaad250 00000009
bfe0: 2ab13958 7e9c2490 2ab034a0 2aaf8e9c 20000010 ffffffff 4fffe821 4fffec21
Exception stack(0xbc3ebfb0 to 0xbc3ebff8)
bfa0: 2aaad000 0000a149 0000000a 2aaad254
---[ end trace 86e9e968b1d2b4d2 ]---
pgd = bc430000
Internal error: Oops: 5 [#117] PREEMPT SMP
Modules linked in:
sp : bc42bdb8 ip : 00000001 fp : 00001def
r3 : bc42a000 r2 : 8060fcc0 r1 : 80040100 r0 : 20000113
Control: 10c53c7d Table: 4c43004a DAC: 00000015
Process hotplug (pid: 970, stack limit = 0xbc42a2f0)
Stack: (0xbc42bdb8 to 0xbc42c000)
bda0: be03e330 800e1ba4
bdc0: bc42beb8 bc0a50b0 00000000 2ab34000 80659660 bfc14680 bfc14680 bc34c4d0
bde0: bfc146bc 800e1ba4 00100077 00000000 bc0a50b0 2ab34000 2ab34000 bc430aa8
be00: bc34c4d0 800dabf8 be08cfd0 800c1cec bc42be7c bc42bef8 00000001 00000000
be20: 00000001 00000001 00000200 800fc198 001580a5 bc430000 00000155 2ab34000
be40: bfc14680 bc0a50b0 bc430aa8 00000001 bfc146bc 800daea8 bc430aa8 00000001
be60: 904ddff8 bfc14680 2ab34014 bc42bfb0 bc0a50b0 bc3f55c0 00000817 2ab34250
be80: bfc146bc 8004e528 1b3dff9e f7236a33 f9fe5477 7a775e83 eaa127fa c4ac5665
bea0: 6a71d950 ad70696f 00000000 00000000 00000000 00000000 00000000 00000000
bec0: bebfbc70 3e9dc334 f70cfc03 e81a4fad bc42a000 8003cc1c 0bfe4000 00001000
bee0: 8060fdf4 00000001 bfc14680 00000817 80613518 2ab34014 bc42bfb0 00000000
bf00: 00000000 2ab34250 00000009 8003e2f4 00000001 bc0a50b0 00000000 800de43c
bf20: bc0a5124 00000000 00000000 0002ab34 00000000 00000003 00000003 00000000
bf40: 00000022 2ab34000 00000000 8022883c bfc146c0 80000013 00000001 2ab34000
bf60: 00000000 bc42a000 00000003 00001000 bc42a000 00000000 00000009 800deae4
bf80: 00100077 0002ab34 00000002 ffffffff 00000000 00001000 000000c0 0000040f
bfa0: 00000007 2ab34000 2ab6a958 80043e84 2ab34000 0000a149 0000000a 2ab34254
bfc0: 2ab6aef8 0000a149 2ab34000 2ab6a958 00000000 00000000 2ab34250 00000009
bfe0: 2ab6a958 7e88f490 2ab5a4a0 2ab4fe9c 20000010 ffffffff 4fffe821 4fffec21
Exception stack(0xbc42bfb0 to 0xbc42bff8)
bfa0: 2ab34000 0000a149 0000000a 2ab34254
---[ end trace 86e9e968b1d2b4d3 ]---
pgd = bc434000
Internal error: Oops: 5 [#118] PREEMPT SMP
Modules linked in:
sp : bc3fddb8 ip : 00000001 fp : 00001e07
r3 : bc3fc000 r2 : 8060fcc0 r1 : 80040100 r0 : 20000113
Control: 10c53c7d Table: 4c43404a DAC: 00000015
Process hotplug (pid: 971, stack limit = 0xbc3fc2f0)
Stack: (0xbc3fddb8 to 0xbc3fe000)
dda0: be03e770 800e1ba4
ddc0: bc3fdeb8 bc0a5160 00000000 2ab98000 80659660 bfc151e0 bfc151e0 bc358660
dde0: bfc1521c 800e1ba4 00100077 00000000 bc0a5160 2ab98000 2ab98000 bc434aa8
de00: bc358660 800dabf8 be08cfd0 800c1cec bc3fde7c bc3fdef8 00000001 00000000
de20: 00000001 00000001 00000200 800fc198 001580a5 bc434000 00000155 2ab98000
de40: bfc151e0 bc0a5160 bc434aa8 00000001 bfc1521c 800daea8 bc434aa8 00000001
de60: ed339bad bfc151e0 2ab98014 bc3fdfb0 bc0a5160 bc3f5960 00000817 2ab98250
de80: bfc1521c 8004e528 3091ac78 63ea48a0 a23d3c65 f9fb9962 eaa127fa c4ac5665
dea0: 7c2de55b 5319b375 00000000 00000000 00000000 00000000 00000000 00000000
dec0: bebfbc70 bb2db06c ded54565 73e8a302 bc3fc000 8003cc1c 0bfe4000 00001000
dee0: 8060fdf4 bc0a5c7c bfc151e0 00000817 80613518 2ab98014 bc3fdfb0 00000000
df00: 00000000 2ab98250 00000009 8003e2f4 00000001 bc0a5160 00000000 800de43c
df20: bc0a564c 00000000 00000000 0002ab98 00000000 00000003 00000003 00000000
df40: 00000022 2ab98000 00000000 8022883c bfc15220 80000013 00000001 2ab98000
df60: 00000000 bc3fc000 00000003 00001000 bc3fc000 00000000 00000009 800deae4
df80: 00100077 0002ab98 00000002 ffffffff 00000000 00001000 000000c0 0000040f
dfa0: 00000007 2ab98000 2ab1e958 80043e84 2ab98000 0000a149 0000000a 2ab98254
dfc0: 2ab1eef8 0000a149 2ab98000 2ab1e958 00000000 00000000 2ab98250 00000009
dfe0: 2ab1e958 7e920490 2ab0e4a0 2ab03e9c 20000010 ffffffff 4fffc811 4fffcc11
Exception stack(0xbc3fdfb0 to 0xbc3fdff8)
dfa0: 2ab98000 0000a149 0000000a 2ab98254
---[ end trace 86e9e968b1d2b4d4 ]---
pgd = bc424000
Internal error: Oops: 5 [#119] PREEMPT SMP
Modules linked in:
sp : bc393db8 ip : 00000001 fp : 00001e27
r3 : bc392000 r2 : 8060fcc0 r1 : 80040100 r0 : 20000113
Control: 10c53c7d Table: 4c42404a DAC: 00000015
Process hotplug (pid: 976, stack limit = 0xbc3922f0)
Stack: (0xbc393db8 to 0xbc394000)
3da0: be03ec38 800e1ba4
3dc0: bc393eb8 bc0a5688 00000000 2aaaf000 80659660 bfc151e0 bfc151e0 bc24f2bc
3de0: bfc1521c 800e1ba4 00100077 00000000 bc0a5688 2aaaf000 2aaaf000 bc424aa8
3e00: bc24f2bc 800dabf8 be08cfd0 800c1cec bc393e7c bc393ef8 00000001 00000000
3e20: 00000001 00000001 00000200 800fc198 001580a5 bc424000 00000155 2aaaf000
3e40: bfc151e0 bc0a5688 bc424aa8 00000001 bfc1521c 800daea8 bc424aa8 00000001
3e60: 1f601d79 bfc151e0 2aaaf014 bc393fb0 bc0a5688 bc3f6440 00000817 2aaaf250
3e80: bfc1521c 8004e528 43925ee2 b31b3fa0 f2cb1b7b d9a927d0 eaa127fa c4ac5665
3ea0: 317ddf88 357d9490 00000000 00000000 00000000 00000000 00000000 00000000
3ec0: bebfbc70 b320003c b3a52b97 bc859467 bc392000 8003cc1c 0bfe4000 00001000
3ee0: 8060fdf4 00000001 bfc151e0 00000817 80613518 2aaaf014 bc393fb0 00000000
3f00: 00000000 2aaaf250 00000009 8003e2f4 00000001 bc0a5688 00000000 800de43c
3f20: bc0a5124 00000000 00000000 0002aaaf 00000000 00000003 00000003 00000000
3f40: 00000022 2aaaf000 00000000 8022883c bfc15220 80000013 00000001 2aaaf000
3f60: 00000000 bc392000 00000003 00001000 bc392000 00000000 00000009 800deae4
3f80: 00100077 0002aaaf 00000002 ffffffff 00000000 00001000 000000c0 0000040f
3fa0: 00000007 2aaaf000 2aae4958 80043e84 2aaaf000 0000a149 0000000a 2aaaf254
3fc0: 2aae4ef8 0000a149 2aaaf000 2aae4958 00000000 00000000 2aaaf250 00000009
3fe0: 2aae4958 7ef29490 2aad44a0 2aac9e9c 20000010 ffffffff 4fffe821 4fffec21
[<800daea8>] (handle_mm_fault+0xcc/0x16c) from [<8004e528>] (do_page5948014 e28 handle kernel paging request at virtual address 11b05003
pgd = bc444000
Internal error: Oops: 5 [#121] PREEMPT SMP
Modules linked in:
PC i: [<800edb1c>] lr : [<800e1ba4>] psr: 60000193
sp : bc45fdb8 ip : 00000001 fp : 00001ee7
r7 : 0b8060fcc0 r1 : 80040100 r0 : 20000113
<4>Flags: nZCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment user
Control: 10c53c7d Table: 4c47804a DAC: 00000015
Process c4a8000)
<0>7da0: be041b28 800e1ba4
7dc0: bc4a7eb8 bc0a5268 00000000 2aabb000 80659660 bfc14682aac6000 2aac6000 bc4e4aa8
3e00: bc1ee318 800dabf8 be08cfd0 800c1cec bc493e7c bc493ef8 000are+0x2c/0x168)
[<800e1ba4>] (anon_vma_prepare+0x2c/0x168) from [<800dedf0>] (expand_downwards+0x14/0x1a0)
[<800dedf0>] (expand_downwards+0x14/0x1a0) from [<800dad10>] (handle_pte_fault+0x618/0x6e4)
[<800dad10>] (handle_pte_fault+0x618/0x6e4) from [<800daea8>] (handle_mm_fault+0xcc/0x16c)
[<800daea8>] (handle_mm_fault+0xcc/0x16c) from [<800db124>] (__get_user_pages+0x124/0x2f0)
[<800db124>] (__get_user_pages+0x124/0x2f0) from [<800f652c>] (get_arg_page+0x50/0xb4)
[<800f652c>] (get_arg_page+0x50/0xb4) from [<800f66f4>] (copy_strings+0x164/0x264)
[<800f66f4>] (copy_strings+0x164/0x264) from [<800f6814>] (copy_strings_kernel+0x20/0x28)
[<800f6814>] (copy_strings_kernel+0x20/0x28) from [<800f760c>] (do_execve+0x1ac/0x268)
[<800f760c>] (do_execve+0x1ac/0x268) from [<80047000>] (kernel_execve+0x38/0x7c)
[<80047000>] (kernel_execve+0x38/0x7c) from [<8008c2fc>] (____call_usermodehelper+0xfc/0x124)
[<8008c2fc>] (____call_usermodehelper+0xfc/0x124) from [<800449d8>] (kernel_thread_exit+0x0/0x8)
---[ end trace 86e9e968b1d2b4ef ]---
Unable to handle kernel paging request at virtual address 1affff22
pgd = 80004000
[1affff22] *pgd=00000000
Internal error: Oops: 5 [#146] PREEMPT SMP
Modules linked in:
pc : [<800edb1c>] lr : [<800e1ba4>] psr: 60000093
sp : bc50dd90 ip : 00000001 fp : 0000208f
r10: 8060fcc0 r9 : 1affff22 r8 : 00000000
r7 : 0bfe4000 r6 : 1affff22 r5 : 000000d0 r4 : bfff2200
r3 : bc50c000 r2 : 8060fcc0 r1 : 80040100 r0 : 20000013
Flags: nZCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment kernel
Control: 10c53c7d Table: 4c50404a DAC: 00000015
Process kworker/u:0 (pid: 1051, stack limit = 0xbc50c2f0)
Stack: (0xbc50dd90 to 0xbc50e000)
dd80: 8064cd64 800e1ba4 00000001 bc0a5108
dda0: 00000000 7effffee 80659660 bfc14d00 bfc14d00 bc02e7fc 00000000 800e1ba4
ddc0: 00000000 bc0a5108 7effe000 7effffee 7effffee bc511fb8 bc02e7fc 800dedf0
dde0: 00000000 00000000 00000000 bc0a5108 7effffee 7effffee bc511fb8 800dad10
de00: 00080001 00000001 00000000 bc511fb8 bfc14d00 60000013 bfc14d00 8bf805c0
de20: 00000000 bc511fb8 bfc14d00 bc510000 000003f7 7effffee bfc14d00 bc0a5108
de40: bc511fb8 00000001 00000000 800daea8 bc511fb8 00000001 bc50c000 00000017
de60: bc0a5108 bc4c9d00 7effffee bfc14d00 00000000 bd95f500 00000000 800db124
de80: bc50c000 00000000 00000001 00000020 00000000 bc50ded4 00000000 00000001
dea0: bd95f500 bc50c000 00000000 bc50c000 00000000 bd95f500 bd95f5b0 800f652c
dec0: 00000017 bc50ded4 00000000 00000000 00000000 00000000 80487fe0 0000000e
dee0: 00000ffc 0000000e 7effffee 800f66f4 bc50c000 bc50df78 bc50c030 00000000
df00: 80631f5a 00000000 00000000 00000000 bd979000 bc50c000 00000000 bd979000
df20: 00000001 bd95f500 bc50c000 bc50df78 bc35a5a0 800f6814 00000000 00000080
df40: bff8be44 800f760c bc1eb000 00000000 007fffff bff8be44 80631f4c bc50df78
df60: bd979000 00000000 00000000 00000000 00000000 80047000 00000000 00000000
df80: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
dfa0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
dfc0: ffffffff bfeeae80 bc1eb000 00000000 ffffffff 00000000 00000000 8008c2fc
dfe0: 00000000 bfeeae80 8008c200 800449d8 00000013 800449d8 4fffc811 4fffcc11
---[ end trace 86e9e968b1d2b4f0 ]---
Unable to handle kernel NULL pointer dereference at virtual address 00000010
pgd = 80004000
[00000010] *pgd=00000000
Internal error: Oops: 17 [#147] PREEMPT SMP
Modules linked in:
CPU: 2 Tainted: G D (3.0.35 #4)
PC is at need_to_create_worker+0x14/0x70
LR is at worker_thread+0x21c/0x37c
pc : [<8008c7ac>] lr : [<8008f094>] psr: 80000093
sp : bffa3f90 ip : bfff0e54 fp : 00000089
r10: 8003d300 r9 : 8003d300 r8 : bffa2000
r7 : 80654220 r6 : 80654228 r5 : 80654220 r4 : bfff33c0
r3 : 80654228 r2 : 80654228 r1 : 80654228 r0 : 00000000
Flags: Nzcv IRQs off FIQs on Mode SVC_32 ISA ARM Segment kernel
Control: 10c53c7d Table: 4c47404a DAC: 00000015
Process kworker/u:0 (pid: 5, stack limit = 0xbffa22f0)
Stack: (0xbffa3f90 to 0xbffa4000)
3f80: 00000013 bffa2000 8003d300 8003d300
3fa0: 00000013 bff8bf08 bfff33c0 8008ee78 00000013 00000000 00000000 00000000
3fc0: 00000000 80093488 800449d8 00000000 bfff33c0 00000000 00000000 00000000
3fe0: bffa3fe0 bffa3fe0 bff8bf08 80093408 800449d8 800449d8 c94091a3 e0d628e0
[<8008c7ac>] (need_to_create_worker+0x14/0x70) from [<8008f094>] (worker_thread+0x21c/0x37c)
[<8008f094>] (worker_thread+0x21c/0x37c) from [<80093488>] (kthread+0x80/0x88)
[<80093488>] (kthread+0x80/0x88) from [<800449d8>] (kernel_thread_exit+0x0/0x8)
Code: e2803008 e1520003 03a00000 013fff1e (e5902010)
---[ end trace 86e9e968b1d2b4f1 ]---
note: kworker/u:0[5] exited with preempt_count 1
Unable to handle kernel paging request at virtual address fffffffc
pgd = 80004000
[fffffffc] *pgd=4fffe821, *pte=00000000, *ppte=00000000
Internal error: Oops: 17 [#148] PREEMPT SMP
Modules linked in:
PC is at kthread_data+0x4/0xc
LR is at wq_worker_sleeping+0xc/0xec
pc : [<80093648>] lr : [<8008fb68>] psr: 20000193
sp : bffa3ca8 ip : 8c018e90 fp : bffa3d5c
r10: bff8ce78 r9 : bff8cf9c r8 : bff8d018
r7 : 00000002 r6 : bffa2000 r5 : bff8ce80 r4 : 00000002
r3 : 00000000 r2 : 00000000 r1 : 00000002 r0 : bff8ce80
Flags: nzCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment user
Stack: (0xbffa3ca8 to 0xbffa4000)
3ca0: 8c018e40 804762c4 80552bb0 bfff8740 00000001 800ebe1c
3cc0: 8bfff300 bfff2300 20000193 80472af8 8060fcc0 8bf97a00 8003ce40 8003ce40
3ce0: 8003c1b4 8003ce40 0bfdc000 800ed368 3ee6ff3d 8007bdbc bff98f60 bff8ce80
3d00: bff90880 bff99464 8064e658 bff98f60 00000000 8003c260 bff8ce80 8007bdd0
3d20: bff8ce80 8003c260 8008c7ae 800be608 00000000 00000000 bffa3d38 bff8ce80
3d40: ffffffff bcc603a0 bff8c000 bff8cf9c bff8cf9c bff8ce78 00000011 8007d054
3d60: 00000000 bffa3d74 bffa2000 00000001 8062b67c bffa3d74 bffa3d74 bcc60504
3d80: 0000008f bffa2000 00000000 00000001 8008c7ae 00000000 8008c7b0 bffa3dea
3da0: 8054b0ec 80047674 bffa22f0 0000000b 00000008 00000000 65000001 33303832
3dc0: 20383030 32353165 33303030 61333020 30303030 31302030 66666633 28206531
3de0: 30393565 30313032 00002029 8003d300 00000089 00000000 00000010 00000017
3e00: bffa3f48 bff8ce80 00000017 8003d300 00000089 80470e5c bffa3f48 8004e628
3e20: 00000000 00000002 bffa3eac 80476c10 00000003 8c020eb8 8c020e40 bcc603a0
3e40: 8c020e40 bcc603a0 8c020e90 00000000 8060fcc0 8006ea14 7fffffff bffa2000
3e60: 00000000 00000010 bffa3ec4 80475cc8 8047a55c 00000000 00000008 00000000
3e80: 00000003 00000017 80613518 00000010 bffa3f48 bffa2000 00000193 8003d300
3ea0: 00000089 8003e2f4 0c800000 00000000 00000000 00000000 00000000 bff8c000
3ec0: 00000003 8060fcc0 bff8c000 0bfe4000 8060fcc0 bff8c2fc 00000000 80075b44
3ee0: 00004011 bffa2000 00000000 bff8bdf4 80075c9c 00000001 bff8be00 00000000
3f00: 00000000 00000003 bffa3f3c 8006cc44 800449d8 00000000 00000000 bff8bdf8
3f20: 20000013 bff8bdf4 bffa2000 00000000 bfff0e05 0000040f 00000007 80654228
3f40: 80654220 80043910 00000000 80654228 80654228 80654228 bfff33c0 80654220
3f60: 80654228 80654220 bffa2000 8003d300 8003d300 00000089 bfff0e54 bffa3f90
3f80: 8008f094 8008c7ac 80000093 ffffffff 00000013 bffa2000 8003d300 8003d300
3fc0: 00000000 80093488 800449d8 00000000 bfff33c0 00000001 00000000 00000000
[<80093648>] (kthread_data+0x4/0xc) from [<8008fb68>] (wq_worker_sleeping+0xc/0xec)
[<8008fb68>] (wq_worker_sleeping+0xc/0xec) from [<804762c4>] (__schedule+0x390/0x6c0)
[<804762c4>] (__schedule+0x390/0x6c0) from [<8007d054>] (do_exit+0x450/0x6e8)
[<8007d054>] (do_exit+0x450/0x6e8) from [<80047674>] (die+0x228/0x284)
[<80047674>] (die+0x228/0x284) from [<80470e5c>] (__do_kernel_fault.part.4+0x54/0x74)
[<80470e5c>] (__do_kernel_fault.part.4+0x54/0x74) from [<8004e628>] (do_page_fault+0x2b4/0x31c)
[<8004e628>] (do_page_fault+0x2b4/0x31c) from [<8003e2f4>] (do_DataAbort+0x34/0x9c)
[<8003e2f4>] (do_DataAbort+0x34/0x9c) from [<80043910>] (__dabt_svc+0x70/0xa0)
Exception stack(0xbffa3f48 to 0xbffa3f90)
3f40: 00000000 80654228 80654228 80654228 bfff33c0 80654220
[<80043910>] (__dabt_svc+0x70/0xa0) from [<8008c7ac>] (need_to_create_worker+0x14/0x70)
Code: eaff987a 8047a6b4 80555190 e590316c (e5130004)
---[ end trace 86e9e968b1d2b4f2 ]---
Fixing recursive fault but reboot is needed!
pgd = 80004000
Internal error: Oops: 17 [#149] PREEMPT SMP
Modules linked in:
CPU: 0 Tainted: G D (3.0.35 #4)
pc : [<8008c7ac>] lr : [<8008f094>] psr: 80000193
sp : bfdb1f90 ip : 8c00c454 fp : 00000009
r10: 8003d300 r9 : 8003d300 r8 : bfdb0000
r7 : 8c0082e0 r6 : 8c0082e8 r5 : 8c0082e0 r4 : bfc1a040
r3 : 8c0082e8 r2 : 8c0082e8 r1 : 00000000 r0 : 00000000
Control: 10c53c7d Table: 4cc6c04a DAC: 00000015
Process kworker/0:1 (pid: 458, stack limit = 0xbfdb02f0)
Stack: (0xbfdb1f90 to 0xbfdb2000)
1f80: 00000013 00000000 8003d300 8003d300
1fa0: bfdb1fc4 bffa1f00 bfc1a040 8008ee78 00000013 00000000 00000000 00000000
1fc0: 00000000 80093488 800449d8 00000000 bfc1a040 00000000 00000000 00000000
1fe0: bfdb1fe0 bfdb1fe0 bffa1f00 80093408 800449d8 800449d8 0940d545 45543a20
---[ end trace 86e9e968b1d2b4f3 ]---
note: kworker/0:1[458] exited with preempt_count 1
pgd = 80004000
Internal error: Oops: 17 [#150] PREEMPT SMP
Modules linked in:
pc : [<80093648>] lr : [<8008fb68>] psr: 00000193
sp : bfdb1ca8 ip : 8c008e90 fp : bfdb1d5c
r10: bfd4da7c r9 : bfd4da7c r8 : bfd4daf8
r7 : 00000000 r6 : bfdb0000 r5 : bfd4d960 r4 : 00000000
r3 : 00000000 r2 : 00000000 r1 : 00000000 r0 : bfd4d960
Flags: nzcv IRQs off FIQs on Mode SVC_32 ISA ARM Segment user
Stack: (0xbfdb1ca8 to 0xbfdb2000)
1ca0: 8c008e40 804762c4 80552bb0 80105d5c bfdb1cdf 00000001
1cc0: bfc1a850 bffc31e0 000001ca 801362c4 00000000 00000000 8003ce40 8003ce40
1ce0: 8003c1b4 8003ce40 5f460127 00000000 5f460127 8007bdbc bfdd6680 bfd4d960
1d00: bfccd760 bfdd6b84 8064e658 bfdd6680 00000000 8003c260 bfd4d960 8007bdd0
1d20: bfd4d960 8003c260 8008c7ae 800be608 00000000 00000000 bfdb1d38 bfd4d960
1d40: ffffffff bfd4d958 bff8c000 bfd4da7c bfd4da7c bfd4da7c 8054b0ec 8007d054
1d60: 00000000 bfdb1d74 bfdb0000 00000001 8062b67c bfdb1d74 bfdb1d74 bfd4dac4
1d80: 00000091 bfdb0000 00000000 00000001 8008c7ae 00000000 8008c7b0 bfdb1dea
1da0: 8054b0ec 80047674 bfdb02f0 0000000b 00000008 00000000 65000001 33303832
1dc0: 20383030 32353165 33303030 61333020 30303030 31302030 66666633 28206531
1de0: 30393565 30313032 00002029 8003d300 00000009 00000000 00000010 00000017
1e00: bfdb1f48 bfd4d960 00000017 8003d300 00000009 80470e5c bfdb1f48 8004e628
1e20: 00000000 00000000 00000800 00000400 00000002 00000001 00000000 00000001
1e40: 00000000 00000800 00000800 00000002 00000800 00000001 00000000 00000001
1e60: 00000000 00000000 2ebb4843 00000000 bfd4d998 8c008e90 f72a41c8 bfdb1ea4
1e80: 2ebb4843 00000017 80613518 00000010 bfdb1f48 bfdb0000 00000193 8003d300
1ea0: 00000009 8003e2f4 00000000 80098a1c 00000000 8c008e90 bc3f6bb8 bc43e01c
1ec0: bfd4d960 bfdb0000 8c008a80 800d37f4 fffffff4 00000000 00000008 00000000
1ee0: 00000000 00000000 00000000 00000001 fffffff4 00000000 00000000 00000000
1f00: 00000004 8c008a9c bfdb1f2c 80085134 8008e094 8c008a90 ffff8ebc 00000064
1f20: ffff8ebc 8c008a80 00000000 a0000113 8c008a80 0000040f 00000007 8c0082e8
1f40: 8c0082e0 80043910 00000000 00000000 8c0082e8 8c0082e8 bfc1a040 8c0082e0
1f60: 8c0082e8 8c0082e0 bfdb0000 8003d300 8003d300 00000009 8c00c454 bfdb1f90
1f80: 8008f094 8008c7ac 80000193 ffffffff 00000013 00000000 8003d300 8003d300
1fc0: 00000000 80093488 800449d8 00000000 bfc1a040 00000001 00000000 00000000
[<804762c4>] (__schedule+0x39user_pages+0x124/0x2f0) from [<800f652c>] (get_arg_page+0x50/0xb4)
pgd = 80004000
Modules linked in:
pgd = 80004000
Modules linked in:
pgd = 80004000
Modules linked in:
pgd = 80004000
Modules linked in:
pgd = 80004000
Modules linked in:
Exception stack(0xbfdb1f48 to 0xbfdb1f90)
1f40: 00000000 00000000 8c0082e8 8c0082e8 bfc1a040 8c0082e0
---[ end trace 86e9e968b1d2b4f4 ]---
pgd = 80004000
Internal error: Oops: 17 [#151] PREEMPT SMP
Modules linked in:
CPU: 1 Tainted: G D (3.0.35 #4)
sp : bffa9f90 ip : 8c014454 fp : 00000009
r10: 8003d300 r9 : 8003d300 r8 : bffa8000
r7 : 8c0102e0 r6 : 8c0102e8 r5 : 8c0102e0 r4 : bfff34c0
r3 : 8c0102e8 r2 : 8c0102e8 r1 : 00000000 r0 : 00000000
Control: 10c53c7d Table: 4c07804a DAC: 00000015
Process kworker/1:0 (pid: 8, stack limit = 0xbffa82f0)
Stack: (0xbffa9f90 to 0xbffaa000)
9f80: 00000013 bffa8000 8003d300 8003d300
9fa0: 00000013 bff8bee8 bfff34c0 8008ee78 00000013 00000000 00000000 00000000
9fc0: 00000000 80093488 800449d8 00000000 bfff34c0 00000000 00000000 00000000
9fe0: bffa9fe0 bffa9fe0 bff8bee8 80093408 800449d8 800449d8 5a785d09 07d0084c
---[ end trace 86e9e968b1d2b4f5 ]---
note: kworker/1:0[8] exited with preempt_count 1
pgd = 80004000
Internal error: Oops: 17 [#152] PREEMPT SMP
Modules linked in:
sp : bffa9ca8 ip : 8c010e90 fp : bffa9d5c
r10: bff8da7c r9 : bff8da7c r8 : bff8daf8
r7 : 00000001 r6 : bffa8000 r5 : bff8d960 r4 : 00000001
r3 : 00000000 r2 : 00000000 r1 : 00000001 r0 : bff8d960
Stack: (0xbffa9ca8 to 0xbffaa000)
9ca0: 8c010e40 804762c4 80552bb0 80105d5c bffa9cdf 00000001
9cc0: bfff3510 bffc31e0 00000008 801362c4 8060fcc0 8bfb3900 8003ce40 8003ce40
9ce0: 8003c1b4 8003ce40 0bfd4000 800ed368 5d63c7ee 8007bdbc bff99ec0 bff8d960
9d00: bff90ee0 bff9a3c4 8064e658 bff99ec0 00000000 8003c260 bff8d960 8007bdd0
9d20: bff8d960 8003c260 8008c7ae 800be608 00000000 00000000 bffa9d38 bff8d960
9d40: ffffffff bff8d958 bff8c000 bff8da7c bff8da7c bff8da7c 8054b0ec 8007d054
9d60: 00000000 bffa9d74 bffa8000 00000001 8062b67c bffa9d74 bffa9d74 bff8dac4
9d80: 00000000 bffa8000 00000000 00000001 8008c7ae 00000000 8008c7b0 bffa9dea
9da0: 8054b0ec 80047674 bffa82f0 0000000b 00000008 00000000 65000001 33303832
9dc0: 20383030 32353165 33303030 61333020 30303030 31302030 66666633 28206531
9de0: 30393565 30313032 00002029 8003d300 00000009 00000000 00000010 00000017
9e00: bffa9f48 bff8d960 00000017 8003d300 00000009 80470e5c bffa9f48 8004e628
9e20: bff8d960 bffa8000 00000020 00000010 ffc28000 802555e4 8060fcc0 bfca2850
9e40: ffc30000 00000001 bc0a08a0 00000000 a0000113 8c010750 8003ce40 8003ce40
9e60: 8003c1b4 bc0a08a0 bffa9ec8 bc03c000 bfca2840 00000010 00000000 00000001
9e80: 00000001 00000017 80613518 00000010 bffa9f48 bffa8000 00000193 8003d300
9ea0: 00000009 8003e2f4 00000000 bc03c000 8049788c 00000000 00000000 80253c68
9ec0: 00000002 00000002 8c010a80 800d37f4 0000000a 00000000 fffffff6 00000000
9ee0: 00000000 00000000 00000000 00000005 fffffffb 00000000 00000000 00000000
9f00: 00000005 8c010a9c bffa9f2c 80085134 8008e094 8c010a90 ffff8eb9 00000060
9f20: ffff8eb9 8c010a80 00000000 a0000013 8c010a80 0000040f 00000007 8c0102e8
9f40: 8c0102e0 80043910 00000000 00000000 8c0102e8 8c0102e8 bfff34c0 8c0102e0
9f60: 8c0102e8 8c0102e0 bffa8000 8003d300 8003d300 00000009 8c014454 bffa9f90
9f80: 8008f094 8008c7ac 80000093 ffffffff 00000013 bffa8000 8003d300 8003d300
9fc0: 00000000 80093488 800449d8 00000000 bfff34c0 00000001 00000000 00000000
Exception stack(0xbffa9f48 to 0xbffa9f90)
9f40: 00000000 00000000 8c0102e8 8c0102e8 bfff34c0 8c0102e0
---[ end trace 86e9e968b1d2b4f6 ]---
1,202 次查看
Hi Tom
error "Unable to handle kernel paging request at virtual address"
may point to memory errors so one can try memory test
i.MX6/7 DDR Stress Test Tool V3.00
Also one can check power supplies (ripples) as described in
IMX6DQ6SDLHDG, Hardware Development Guide for i.MX 6Quad, 6Dual, 6DualLite, 6Solo Families of Applic...
