We are designing a custom carrier board based on I.MX 8m plus processor, where we are using MIPI port 1 and not using MIPI port 2 and DSI ports, while referring the design guide and previous forums for this configuration we could not find any recommendations, please share the wright approach for handling the un used MIPI and DSI ports in the processor " PN : MIMX8ML8CVNKZAB "
Hi @Sak_ed,
Please have a look on the following community case:
Solved: i.MX8M PLUS MIPI unused termination - NXP Community
If I understood correctly, that is the same configuration you want to use.
I hope this information will be helpful.
Have a great day!
