I. MX 8mn ddr3levk yocto project build problem
1,478 次查看
jack_huang1
Dear:
     I use the ubantu 20.04 virtual machine
     I use the next command to build the imx8mnddr3levk linux L5.10.35.2.0.0
$ DISTRO=fsl-imx-xwayland MACHINE=imx8mnddr3levk source imx-setup-release.sh -b imx8mnD3l_l535xwayland
$ bitbake imx-image-multimedia
At the end of “bitbake imx-image-multimedia”, do-image-wic generate an error, reference this error with the log file “log.do_image_wic.17779”
The log file is attached.
Thank you!
1,456 次查看
Harvey021
Hello Jack.
For better understand this problem, please provide details as followings:
What steps you have taken before the image build?
what the Virtual machine is and its version?
Harvey
1,453 次查看
jack_huang1
After changing the Ubuntu version 18.04, the problem is resolved.Thank you!
