I MX 1060 PIN CONFIGURATION
achal
This is the pic of pinmux.c file of enet_txrx_example of imx rt 1060.
I want to ask how actually the values  of pin configueration is decided. like 0xB0A9U
Is there any document which states that for achieving some particular function  0xB0A9U , this pin configuration needs to be set?
jingpan
Hi @achal ,
It's pad control register, not pad mux register. Those value will be written into pad control register.
Jing
jingpan
Hi @achal ,
This function write SW_PAD_CTL_PAD_xxxx SW PAD Control Register. You can refer to, for example, page 410 in reference manual.
Jing
achal
Here  only reset value is mentioned
jingpan
Hi @achal ,
Jing
