How to work NAND boot if 2nd page of FW1 is Bad.
takayuki_ishii
I read an errata ERR008506 and understand about FW2 load condition.
Our NAND have 2KB page size.
In this time if first page of FW1 is bad, it will start to load FW2 by this errata.
If 2nd page of FW1 is bad, ROM read 4KB (frist and 2nd page of FW1)
and ECC checking fails because 2nd page is bad.
In this condition, how to work ROM bootloader after this error?
 1) start to load FW2?
 2) load 3rd page of FW1?
 3) others
Ishii.
Labels (2)
takayuki_ishii
Hello Igor,
Thank you for your support.
I will answer it to my customer.
Ishii.
takayuki_ishii
Hello Igor
I can find my answer from sect. 8.5.2.5 in RM(sect 8.5.2.3 is not direct answer to me).
In this section, it say that
"flash updater or gang programmer applications need to swap Bad Block Information (BI) data to byte 0 of metadata area for
every page before programming NAND flash."
So my understand is that to skip Bad block in ROM boot, it must need to inform in DTTB or set BI in byte0.
Is it correct?
Ishii.
Hi Ishii
yes this is correct.
takayuki_ishii
Hello Igor
Thank you for your quick response.
Our customer report us that when DBBT has bad block information about page2 of FW1,
It can boot by FW2.
    BLOCK 03              FCB
    BLOCK 47              DBBT
    BLOCK 89              Firmware1
    BLOCK 1015          unused
    BLOCK 1617          Firmware2
    BLOCK 1823          unused
But it have no information in DBBT, only marked it, it cannot boot both FW1 and FW2.
    BLOCK 03              FCB
    BLOCK 47              DBBT (have no bad information about Block9)
    BLOCK 8                   FirmWare1_1
    BLOCK 9                   Bad
    BLOCK 10                 FirmWare1_2
    BLOCK 1115          unused
    BLOCK 1617          FirmWare2
    BLOCK 1823          unused
NAND writer detect bad condition in Block9 so skip to write Block9 and
write to block10 the second half of FW1.
Please teach me how load a firmware from NAND by boot ROM?
Ishii
Hi Ishii
as described in sect.8.5.2.3 Firmware Configuration Block i.MX6DQ RM
"The location information for DBBT search area, FW1, and FW2 are all specified in the FCB."
Hi Ishii
