How to use uuu emmc flash *. wic.zst file?
已解决
跳至解决方案
6,229 次查看
lidongxu
I previously built version L5.10 of Yocto's BSP, which has a mirror file of * wic.bz2, so I used this command to flash.
uuu -b emmc_all imx-boot-imx8mp-ai-robot-sd.bin-flash_evk imx-image-multimedia_imx8mp-ai-robot.wic.bz2
However, when building version L6.1, it generated *. wic.zst. Should I use the same command to flash? Do I need to make some modifications?
标签 (1)
标记 (1)
1 解答
6,189 次查看
joanxie
refer to the user guide
The following command decompresses zst file and writes into eMMC:
uuu -b emmc_all <bootloader> <rootfs.wic.zst/*>
在原帖中查看解决方案
4 回复数
6,190 次查看
joanxie
6,187 次查看
lidongxu
Thank you very much for your reply!
Does this mean that there is no difference between. wic.bz2 and. wic.zst? For Flash ? Can I understand it this way ?
6,180 次查看
joanxie
 they are just different zip format, old bsp version uses bz2, current bsp uses zst, if you use the latest uuu tool, which should support them both
6,174 次查看
lidongxu
Thank you very much for your help!
Best wishes
