Hi, i had tried to use the IOCTL in linux to set the GPIO pin on External IO Expander on I.MX8M Plus EVK to became Interrupt pin (Rising edge trigger), but i got the error message on terminal which unable to set the rising on that GPIO pin. May i know how to solve it ?
解決済! 解決策の投稿を見る。
Hi @Jimmychea,
I hope you are doing well.
Hi @Jimmychea,
Expander GPIO already exposed to /dev/gpiochip5, i intend to use IOCTL command to monitor interrupt pin 8 on /dev/gpiochip5, may i know how to do that ?
Cannot be using IOCTL command ?
Hi @Jimmychea,
