How to use rpmb in imx8x
shalanyang
IMX8X  RPMB use ?
             hello, could anyone tell me how to use rpmb in imx8x? tks!
like this ?
mmc rpmb write-key <rpmb device> <key file>
mmc rpmb write-block <rpmb device> <address> <256 byte data file> <key file>
mmc rpmb read-block <rpmb device> <address> <blocks count> <output file> [key file]
Hi Shalan
it can be used with mmc-utils :
hardware - How to access Replay Protected Memory Block (RPMB) in eMMC? - Information Security Stack ...
shalanyang
I know to use it,tks!
Raana
Hi Shalan Yang,
Can you please share the exact inputs to below mentioned mmc commands?
Because, I'm also trying to read/write the RPMB partition in i.Mx8.
Thank You.
J.P.Raja
