Dear Josh,
Thank you very much for your support. It is now compiled and added to image, but the problem is, I still can not use opencv. Now, I found an opencv folder inside /usr/share, but it does not include neither executable nor source code. It only includes a samples folder which contain some images and videos. Also, I can not find any opencv libraries.
I don't know if you have expertise on opencv, but do you know what should I do to use it now? Thank you for your support.
Fikret Alim
