How to use nxp pin config tool for pin multiplexing in imx8mplus in yocto project?
vivek338
Hi !
I need help on pin multiplexing using config tool and integrate in yocto project. I am working imx8mplus development board.
Please help!
florian_arndt
Hello vivek,
so what is your specific question?
vivek338
Hi !
I want to change pin functionality using config tool and add that dts to yocto project.
Chavira
Hi @vivek338 !
Thank you for contacting NXP Support!
As @florian_arndt mentioned, Config Tools helps to generate a customized device tree according to your necessities.
To compile your customized device tree you can follow the next instructions.
https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/How-to-use-Devshell-to-compile-device-tr...
Best Regards!
Chavira
florian_arndt
Hello @vivek338,
just select the pin multiplexing you want to have via the "Pins Tool" and then export it via the menu. You can find some pictures in the appendix.
1) Configure your multiplexing by clicking on the specific pins in the CPU ball grid.
2) Or configure your multiplexing via interface selection in the left column.
3) Then export it.
4) Choose what you want to export.
5) Select your target directory.
I hope this helps.
