How to use freescale IO Mux tool output files in LTIB to support a custom design (ex. add new pads)?
1,636 次查看
YamilGarcia
I would like to change some pads configuration and add new pads to a custom design based on sabrelite board. I'm using freescale IO Mux tool to configure pads according to my needs. I've read the user manual for IO Mux tool but I couldn't figure out how to integrate IO mux tool's output file to LTIB in order to build the kernel.
I've checked every supported platform in LTIB and I couldn't see the output files format generated by IO Mux tool.
Can someone give a hint on this matter?
How to integrate IO Mux tool's output files into LTIB to build a kernel?
1,275 次查看
Yuri
I am afraid, the IOMUX tool's output is not intended for simple / automatic embedding into Linux building systems as LTIB.
The IOMUX can provide source examples, which may be used for manual correction of driver's sources.
1,275 次查看
YamilGarcia
Thanks Yuri, that's what I thought.
