Thank you for your interest in NXP Semiconductor products,
There is no current SW implementation for this.
If you are planning to use the UART interfaces, you could create a driver calling the UART TX function from BSP, otherwise, if you will connect ADDRESS and DATA, you would need to create the driver calling GPIO functions.
