How to use TL16C554 with imx8m plus CPU
362 次查看
armmey
hello. We use imx8m plus cpu I'm trying to use the TL16c554 uart expansion chip. I need an address and data interface, is there a way to use it? If so, please provide detailed explanation.
305 次查看
JosephAtNXP
Thank you for your interest in NXP Semiconductor products,
There is no current SW implementation for this.
If you are planning to use the UART interfaces, you could create a driver calling the UART TX function from BSP, otherwise, if you will connect ADDRESS and DATA, you would need to create the driver calling GPIO functions.
