How to use MCIMXHDMICARD for Sabre Smart Device?
1,155件の閲覧回数
minhyukoh
I am using the Sabre Smart Device hardware, and bought the MCIMXHDMICARD which converts MIIPI to HDMI port, and I heard that it worked with i.MX6Q.
and also, I put the linux rather than Android in this platform.
However, I was not able to get the HDMI LCD ON. The one HDMI port works fine, but since I am trying to use the 2x HDMIs, I need to make the MIPI-to-HDMI work.
Can you help? Probably, if you could provide mipi-to-hdmi uboot video parameter, that will be great.
Thanks.
ラベル(5)
965件の閲覧回数
jimmychan
I think the MCIMXHDMICARD cannot converts MIPI to HDMI port.
On the Sabre Smart Device board, there is only one HDMI output port. For two HDMI output, you need to make your own design board. Or you may create a convertor board by yourself that for LVDS to HDMI (e.g. using CH7036).
