How to upgrade rootfs(ubifs) in linux
1,534 次查看
guochgz
hello, everyone:
      I have a custom board with imx6ull,  there is four patition.
      1. uboot partition
      2. kernel partition
      3. dtb partition
      4. rootfs partition (ubifs)
     now I need to upgrade this system when the system is running. but at this time, the /dev/mtd3 is already mounted by kernel. when I flash_erase this partition(rootfs), all the bins(executable programs) will be lost.  and the status of /dev/ubi0_0 is "Device or resource busy" .
     what am I supposed to do?
标签 (2)
1,427 次查看
b36401
You can create another rootfs partition for upgrade.
I mean you can make a small OS that can perform the upgrade of original rootfs and place it on separate one.
