How to update Warpboard's u-boot
1,653 次查看
weifuchang
I want to update the u-boot of warpboard, and used imx_usb tool to load new u-boot into memory, but it will use default u-boot after reboot.
Can I save the u-boot in warpboard by any command?
标签 (2)
4 回复数
1,539 次查看
Rita_Wang
Hi Weifu,
When the u-boot boot up you can change and set the parameters in the command line.
Dan
Note: If this post answers your question, please click the Mark Correct button. Thank you!
1,539 次查看
weifuchang
Hi Dan
How to flash the new u-boot image to warpboard?
Wei-Fu Chang
1,539 次查看
Rita_Wang
Hi Wei-Fu Chang,
You can use mfgtool to write the u-boot image to your board.
Best Regards
Dan
1,539 次查看
weifuchang
Hi Dan
Could you teach me  how to use mfgtool to write warpboard step by step?
Thanks a lot
Wei-Fu Chang
