How to test wdog2(TZ) in uboot and kernel?
1,355件の閲覧回数
zohanlin
Hi all,
I test wdog2 on i.MX6Q with Yocto(kernel 4.9.88)
I tried to test wdog2(TZ) in u-boot and kernel.
In uboot, I  modified ./drivers/watchdog/imx_watchdog.c and replaced WDOG1_BASE_ADDR with WDOG2_BASE_ADDR, it not worked.
In kernel, I don't know how to ensure the wdog2 is worked. But when system reboot, WDOG2_B would be pull low.
I found some info in imx6 Watchdog ,but page not found.
Could someone tell me how to test it?
Thanks for your help.
ラベル(4)
タグ(1)
2 返答(返信)
1,285件の閲覧回数
Hi zohan
wdog2 is enabled in imx6qdl-sabresd.dtsi
imx6qdl-sabresd.dtsi\dts\boot\arm\arch - linux-imx - i.MX Linux kernel
for testing one can try wdog unit test:
wdog\test - imx-test - i.MX Driver Test Application Software
1,285件の閲覧回数
zohanlin
Hi igor,
Thanks for you relpy.
But I have a question.
Does wdog2 work on trust zone?
zohan
