How to tell the difference between imx6Q and imx6Q-pop
2,073 次查看
richardhu
Hello, all:
For now, we have two different type of CPU:
imx6Q and imx6Q-pop
Are there any method to tell the difference between this two CPUs ? (Read fuse register or CPU ID?)
Because we would like to tell the difference in SPL, then give different DDR settings.
Thank You !
BR,
Richard
标签 (2)
6 回复数
1,795 次查看
Rita_Wang
Hi Richard,
I will confirm it for you, please have a wait.
Have a nice day
Dan
1,795 次查看
richardhu
Hello, Dan:
Sorry to bother you.
How are things going?
Our product will be shipped in the near future.
BR,
Richard
1,795 次查看
Rita_Wang
Hi Richard,
The i.mx6Q and i.mx6Q-pop is compatible on hardware. But they have difference cache and RAM, so the software and BSP are different. Of cause the price is also not the same, the i.mx6Q-pop is more expensive than the i.mx6Q. I am searching for the details difference document on them, I will sent it to you when I get it.
Dan
Note: If this post answers your question, please click the Mark Correct  button. Thank you!
1,795 次查看
richardhu
Hello, Dan:
We still keep track on the status.
Is there any updated information?
Thank You !
BR,
Richard
1,796 次查看
Rita_Wang
Hi Richard,
I have got the reply update from our expert team.
The CPU speed is 800MHz in MX6Q-POP and CPU speed is 1GHz in MX6Q (consumer).
Maybe you can check the "SPEED_GRADING" in fuse to identify the chip.
Or use external pull-up/pull-down in GPIO pins to identify the PCB.
Hope this can help you.
Have a nice day
Dan
1,796 次查看
Rita_Wang
Hi Richard,
I have escalated it to our expert team and I am wait for them reply to me. From the datasheet http://cache.nxp.com/files/32bit/doc/data_sheet/IMX6DQCPOPEC.pdf?fpsp=1&WT_TYPE=Data%20Sheets&WT_VEN...  only see the part num is different. As I do not use or familiar with the imx6Q-pop, and do not search the details document about it, so sorry for late reply.
Have a nice day
Dan
