How to take kernel crash log backup from /var/log/messages to another file using klogd and syslogd
bandarulavanya
Hi Friends,
I want to take the backup of kernel crash logs in to a file in /home folder, how we can do it, if any one done already can you please give me some references.
FYI
linux version - 3.0.35, my board is similar to imx6 sabresd board
Thanks & Regards,
Lavanya
Tags (2)
gusarambula
Hello Bandaru Lavanya,
You should be able to edit which logs are recorded and to what files on the /etc/syslog.conf file.
There is some useful guidelines on this on the following link. These are directed towards BSD but the log configuring is the same as Linux.
11.7. Configuring System Logging
I hope this helps!
